Site-to-Site ISA 2004 to PIX 515 Multi IP's
Site-to-Site ISA 2004 to PIX 515 Multi IP's - 27.Oct.2005 3:59:00 PM
JBakels
I've been having one heck of a time trying to get this to work.
Our ISA 2004 system has 5 external IP's for its external NIC. Each IP either hosts a website or provides incoming e-mail (i.e. www.domain-a.com, www.domain-b.com, mail.domain-c.com)
Should I only have one external IP?
I'm trying to create a Site-to-Site VPN to a PIX 515. I have other Site-to-Site VPN's that are working. They are to PIX 501's.
If I use SHA1 it will not connect. If I use MD5 I can connect one way with Remote Desktop but can't ping.
It appears that the other VPN's may be conflicting. It also appears the other external IP's may be causing a problem.
Jerry
RE: Site-to-Site ISA 2004 to PIX 515 Multi IP's - 27.Oct.2005 4:34:00 PM
JBakels
I also noticed that IPSec is showing the other VPN's in the trouble VPN's policies.
RE: Site-to-Site ISA 2004 to PIX 515 Multi IP's - 27.Oct.2005 6:16:00 PM
ClintD
As long as every IPSec Tunnel uses the primary IP of the external NIC, then you'll be fine. There are problems with HTTP and other protocols once you switch to using a secondary, tertiary, etc... IP for the ISA side of the IPSec Tunnel.
If ISA is installed on Windows 2000, then you're only able to have one Main Mode policy - under Windows 2003, each Remote Site can have its own Main Mode policy.
RE: Site-to-Site ISA 2004 to PIX 515 Multi IP's - 28.Oct.2005 11:41:00 AM
JBakels
Thanks for the reply. Why would the other IP's appear the the IPSec policies? Won't this cause a problem with the authentication? Should the PIX have all my external IP's in its policy?
Jerry
RE: Site-to-Site ISA 2004 to PIX 515 Multi IP's - 28.Oct.2005 1:08:00 PM
ClintD
Do you mean the Security Associations show up in IPSec Monitor? Or do you mean the filters?
That's a weird one - I can't think of anything off the top of my head that would cause either...
RE: Site-to-Site ISA 2004 to PIX 515 Multi IP's - 28.Oct.2005 2:04:00 PM
JBakels
They show up in the IPSec monitor. I have another ISA server (on a test network) that only has one IP for the outside and IPSec monitor looks correct. I've thought about rebuilding the trouble system but that is the last thing I want to do.
Thanks for your help.
Jerry
RE: Site-to-Site ISA 2004 to PIX 515 Multi IP's - 31.Oct.2005 7:44:00 AM
JBakels
Is anyone here using multiple IPs on the external interface and have a site-to-site vpn working (bi-directional)?
RE: Site-to-Site ISA 2004 to PIX 515 Multi IP's - 31.Oct.2005 1:29:00 PM
JBakels
By the way I'm using Windows 2003.
RE: Site-to-Site ISA 2004 to PIX 515 Multi IP's - 31.Oct.2005 4:32:00 PM
JBakels
I stand corrected on the other VPN's working. They will let me remote desktop one way. I can't ping or access any internal resourced either way.
When ISA has multiple IP's assigned to the external interface should I create a network for each or should they all be part of External? Right now I don't have any networks created for the external IP's.
RE: Site-to-Site ISA 2004 to PIX 515 Multi IP's - 1.Nov.2005 2:56:00 PM
JBakels
I noticed something interesting. I can access network resources from systems that have a default gateway. All normal servers and workstations do not have a default gateway. The workstations all use the firewall client.
Anyone know why this would happen?
RE: Site-to-Site ISA 2004 to PIX 515 Multi IP's - 1.Nov.2005 3:08:00 PM
LLigetfa
FWC does not facilitate full network resource access. For that, S-NAT is required. It has been discussed here several times recently.
RE: Site-to-Site ISA 2004 to PIX 515 Multi IP's - 1.Nov.2005 3:21:00 PM
JBakels
I could not find anything on that under VPN with regard to site to site.
So what about the servers that don't have the firewall client and don't have a default gateway?
I've alway thought the FWC was supposed to overcome the networking issues.
What your saying is to create network rule using NAT?
RE: Site-to-Site ISA 2004 to PIX 515 Multi IP's - 1.Nov.2005 3:27:00 PM
LLigetfa
Sorry, I am out of my league when it comes to VPN site to site. I only know the limitation of the FWC. Maybe ClintD will hap to come along and bail me out.
RE: Site-to-Site ISA 2004 to PIX 515 Multi IP's - 1.Nov.2005 4:19:00 PM
JBakels
Well, after reading throught the Firewall Client forum I've decided to set the default gateway on the systems requiring access.
What a depressing issue.
RE: Site-to-Site ISA 2004 to PIX 515 Multi IP's - 9.Nov.2005 8:01:00 AM
JBakels
I feel like a total idiot. A default gateway is not needed at all. All that is needed is a route on the client system accessing the remote system and a route on the remote system to the client network. A very simple solution.
