Site-to-Site VPN RRAS to ISA2004 Problems
All Forums >> [ISA Server 2004 Firewall] >> VPN >> Site-to-Site VPN RRAS to ISA2004 Problems Page: [1]
Site-to-Site VPN RRAS to ISA2004 Problems - 16.Jul.2007 6:28:37 PM
yatesee
Howdy,
I have ISA 2004 SP3 standard set up in our HQ. IP range is 172.16.16.0/20. Running Windows 2003 SP1.
Spanning off that is a branch office DC running Win2k3 SP2 with a 192.168.20.0/24 range.
The site-to-site VPN is using PPTP. Instructions fully followed from http://www.isaserver.org/tutorials/gatewaytogatewaywithdcpart2.html
So, the vpn works peachy. I can ping my internal servers from the branch office fine, and vice versa. Name resolution again is no problem. The problem i have is that after an undertermined time, although the VPN is still connected in RRAS and in ISA, it does not ping though. Once i disconnect the VPN tunnel (at either end) and then reconnect, it works grand again.
I havnt done enough tests to see whether it does it on idle or after a set period of time - i think its random. I have just started copying 1gb of data over from Branch to HQ, so we'll see how far that gets.
There is an MS Kb article on a VPN dropping after 15mins, but this does not apply in my case, as it definetly works fine for longer than that.
Can anyone assist or has anyone seen this issue before?
Cheers in advance chaps,
Yatesee
RE: Site-to-Site VPN RRAS to ISA2004 Problems - 18.Jul.2007 9:14:55 AM
Install Win2003 SP2 on both VPN gateways and see if that fixes the problem. Make sure to make the Registry entry to fix the RSS bug.
(in reply to yatesee)
RE: Site-to-Site VPN RRAS to ISA2004 Problems - 20.Jul.2007 6:57:43 AM
yatesee
This morning i installed SP2 for W2K3, and applied the registry fix for RSS. Rebooted at appropriate times.
The problem still exists.
Is there anything else i can try? If you need more info, give me a shout,
RE: Site-to-Site VPN RRAS to ISA2004 Problems - 23.Jul.2007 9:11:10 PM
Check this week's newsletter. I included a link to a hotfix that might help this problem.
RE: Site-to-Site VPN RRAS to ISA2004 Problems - 31.Jul.2007 3:22:48 AM
yatesee
Are you talking about "Routing and Remote Access stops responding in Windows Server 2003"?
My symptons are not exactly as described in this article.
I can get the VPN back up and working if i disconnect it from the RRAS side (branch office), but if i do the same on the HQ Side that is running ISA2004, it does not fix the problem.
I have requested the hotfix anyway, so I'll let you know how i get on with it. (Do i install it on both gateways, or just the RRAS side?)
RE: Site-to-Site VPN RRAS to ISA2004 Problems - 1.Aug.2007 3:30:41 AM
yatesee
I have tried to apply this hotfix, but i have a service pack that is later than the version of this hotfix.
