Skip Auth. for an application
All Forums >> [ISA Server 2004 Firewall] >> Firewall Client >> Skip Auth. for an application Page: [1]
Skip Auth. for an application - 4.Sep.2007 10:31:07 AM
erkan102
Hello,
We have an application which is not make authentication while it is connectting to internet. I noticed  that this application connections are displaying anonymous at the monitoring tab in isa. I can run this application without any problem when i uncheck Require Authentication checkbox on the internal. But i must use Require
Authentication.
In this stuaton i need a specific configuration for skip authentication only this application.
Is there any solution for this problem in isa?
< Message edited by erkan102 -- 4.Sep.2007 10:38:26 AM >
RE: Skip Auth. for an application - 4.Sep.2007 2:13:35 PM
Authentication.
Why you must use this option ??
you can force authentication thru your rules !!
(in reply to erkan102)
RE: Skip Auth. for an application - 5.Sep.2007 7:44:33 AM
erkan102
I am using this option for access deny unwanted persons to internet. After you said it, i unchecked Require All Users to Authenticate check and unwanted persons continue cant access to internet, too. Thats good. And application is running too.
But, when i must use this option or what for?
Not: Sorry about my english.
RE: Skip Auth. for an application - 5.Sep.2007 8:18:10 AM
Never Use this option.
it brings trouble more that it solves.
if you want enforce authentication, then Configure your Access rules to be based on Users/groups instead of the ALL Users group.
RE: Skip Auth. for an application - 5.Sep.2007 8:36:59 AM
erkan102
Thank you very much for your valuable descriptions elmajdal.
Application problem solved...
RE: Skip Auth. for an application - 5.Sep.2007 8:46:05 AM
Glad to hear that and thanks for the follow up.
Tarek
