Solution-Activesync and Forms authent
Solution-Activesync and Forms authent - 14.Aug.2004 5:29:00 PM
BobW
Not sure if anyone has seen/done this,but it makes my happy!
My users, how do you say, have troubles with anything other than a simple logon process for OWA. Some of them don't even know there username let alone the domain....
Activesync for handhelds (i.e Ipaq in my case) requires Integrated Windows, which in turn messes up the basic authentication required for my users.
MS had an article on performing a reg hack etc, but it was pulled for some reason.
So here is what I did:
I set authentication on the exchange server on the "exchange" virtual directory for basic AND Integrated Windows Authenticated. This ruins your basic authent method and requires the entering of a domain name to logon to OWA.
THEN I set up the ISA 2004 publishing rule to use forms based authentication. Then I edited the the logon.asp on the exchange server to include the default domain name (see the article at msexchange.org there is even a download for a premodified logon.asp).
THEN, to make the screen not show domain\username but rather username (as to not confuse my users) I modified the strings.txt file on the ISA box located in "C:\Program Files\Microsoft ISA Server\CookieAuthTemplates".
Throw in a link translation for http: to https: and you end up with:
1. An easy way for your users to login to OWA (not to mention a way to stop folks fromleaving OWA logged in on public workstations).
2. An easy way to redirect OWA to https via link translation.
3. A way to enable Activesync (via https:) without messing with IIS to heavily, hacking the registry, and a way to use IIS 5 (which MSs pulled article did not address).
There you are....works great...just make sure to backup the files before you modify them,
Bob
NOTE: looking forward to feedback and stories that it works for others! [ August 15, 2004, 03:14 AM: Message edited by: BobW ]
RE: Solution-Activesync and Forms authent - 15.Aug.2004 3:10:00 AM
BobW
What do you mean by "the dreaded DS2MB process is waiting to bite you!" please elaborate.
and how about "Sounds like you edited authentication through IIS Manager cos FBA messes things up." All I changed was the authentication on the Exchange virtual folder in IIS manager!
With regard to link translation. My users go to a basic website that they then must click on a link to get to the OWA site or any of the other available resources. I simply told the ISA box to change all requests for http://www.sitename.com to https://www.sitename.com at the ISA box. The outside world is connecting to the ISA box intially via port 80, but then the ISA box switches them to SSL, but between the ISA and exchange box it is running http. I have also set the publishing rule to require SSL effectively closing th direct port 80 to exchange possibility.
Any and all tips/suggestions you can give me is MUCH appreciated!
Thanks, Bob [ August 15, 2004, 05:03 AM: Message edited by: BobW ]
RE: Solution-Activesync and Forms authent - 15.Aug.2004 4:39:00 AM
BobW
OK, I anwered some of my own questions.
I did not realize I should be modifying OWA authentication via "system manager"! I guess that the IIS mod is something I had leftover from my 5.5 days! Pretty embarassing, but hey, never taken a computer class in my life....
After your post I bounced the server. It seems to work fine. Then I modified the OWA authent to be basic/integrated via system manager (it only showed basic although IIS was set for both).
I then tried draggin and dropping with no issues.
So just to be clear I have basic/integrated on the E2K3 box with FBA on the ISA 2004 box.
Everything seems to be OK still.
Thanks for any help/insight, Bob
NOTE: Sorry to beat this to death, but modifying Exchange server spooks me. [ August 15, 2004, 04:43 AM: Message edited by: BobW ]
RE: Solution-Activesync and Forms authent - 16.Aug.2004 2:03:00 PM
paulbaldwin
Hi Bob,
Yikes, I misread your post. You must have been scratching your head over how I could have figured you were using IIS Manager! But at least we cleared that one up and you gained a tip. FBA on ISA (I read Exchange!), that's fine. Avoiding FBA on Exchange avoids much head-banging.
Because you said 'link translation' I assumed you were using the ISA feature of that name (which translates responses). Fortunately that isn't what you were doing because that would have created the weird effects I mentioned.
RE: Solution-Activesync and Forms authent - 16.Aug.2004 4:28:00 PM
BobW
We are so close to being on the same page it is rather painful! I am using the ISA link translation BUT only on my portal type page, thus makign all links on my portal page (one of which is OWA) change to SSL.
This way if my internal users use OWA from the same portal page the internal listener does NOT redirect them to SSL. This way I don't have to have SSL on the exchange server, only on the ISA box.
At any rate, going back to the orginal post, is the coming article on msexchange.org using a similar solution to the basic/forms/activesync issue? Does mine sound OK?
Thanks, this is my last post post I swear! Bob
RE: Solution-Activesync and Forms authent - 16.Aug.2004 7:02:00 PM
paulbaldwin
Ahhh, I see now. Nice!
Unfortunately everyone else reading this thread has gone, thinking 'what are they rabbiting about'. Sorry about that; my fault.
You've gone around the problems with EAS etc, and it is fine - you're happy aren't you. My solution isn't quite the same but you can see it soon and determine the pros and cons of each.
