Some problems with SSL Bridging
All Forums >> [ISA Server 2004 General ] >> Web Publishing >> Some problems with SSL Bridging Page: [1]
Some problems with SSL Bridging - 9.Feb.2004 9:12:00 PM
jpierini
LAB
- Windows 2k3 Domain Controller with certificates services and IIS 6.0 (ASP enabled) - Provides certificates through Web Enrollment.
- ISA 2K4 Beta 2 run in a W2k3 Standard.
Internal: 192.168.5.0/24
External: 192.168.0.6
ISA Server member of contoso.com domain.
I followed all the instructions in publishing a secure site using a certificate (I have only one server to publish).
I can access the https://server/certsrv page from the internal network but when I try form outside I get the following error:
500 Internal Server Error - The target principal name is incorrect. (-2146893022)
Internet Security and Acceleration Server
Can somebody helpme !
Best regards,
Javier
RE: Some problems with SSL Bridging - 10.Feb.2004 5:32:00 AM
Hi Javier,
Check out my article on the dreaded 500 error over at www.isaserver.org/shinder
Make sure your redirect is using the same name as the certificate's common name on the internal network.
(in reply to jpierini)
RE: Some problems with SSL Bridging - 10.Feb.2004 11:59:00 PM
jpierini
Hi Tom, thanks a lot for your advice. I saw your article and I can configure properly the certificate's name. Now I have a problem with authentication. If I connect to IIS from internal LAN (with the certificate's name) no problem.
If I connect to IIS from external:
- Without Ask unauthenticated user for identification (Web Listener->Properties->Preferences-> Authentication) I get the following error: HTTP Error 401.1 - Unauthorized: Access is denied due to invalid credentials.
Internet Information Services (IIS)
- With the checkbox enabled: I can't authenticate. I get the authentication box from ISA, but any user or password combination is refused. The default domain is contoso.com and the ISA server is a member server of that.
In both cases, the authentication is set to Basic.
Best wishes,
Javier
RE: Some problems with SSL Bridging - 15.Feb.2004 7:23:00 PM
Hi Javier,
Does the ISA firewall belong to the same domain as the IIS site? Or, are you using RADIUS to authenticate external users?
RE: Some problems with SSL Bridging - 16.Feb.2004 7:39:00 PM
jpierini
The ISA an IIS belongs to contoso.com domain.
I have a situation concerning authentication. First, if I enable Ask unauthenticated Users for Identification on the firewall (domain: contoso.com; authentication set to Basic, authentication in IIS set to Basic..same domain/realm) the configuration doesn't work. If I uncheck Ask.... and then the IIS requests for authentication, all works fine.
Second, I enable IAS on the same certificate's DC....and try Radius Authentication....Nothing.
Why I cann't set the authentication at the firewall level?
Javier
RE: Some problems with SSL Bridging - 17.Feb.2004 12:44:00 AM
Hi Javier,
Confiugre the Web Publishing Rule to forward basic authentication credentials. That way, the user can authenticate to the firewall and then connect to the Web site. This is the delegation of basic authentication feature.
RE: Some problems with SSL Bridging - 17.Feb.2004 10:53:00 PM
jpierini
I've configured Forward the User Identity to the Published....from the user's tab, but if I enable Ask for unauthenticated....the Autenthication Box it doesn't references to contoso.com domain/realm even I setted in the properties of the web listenner. I cann't validate the account, and after 3 shots access is denied. So, I've Forward The User identity to the Published...enabled but Ask for unauthenticated Users....disabled....and works. It doesn't work for Radius authentication too.
Another issue is that I cann't get a computer certificate for external (non-domain) computers to enable L2TP/IPSec access, but that is another question.
Thanks in advance,
Javier
RE: Some problems with SSL Bridging - 18.Feb.2004 4:49:00 AM
Hi Javier,
I'll test the RADIUS authentication problem and see if I get the same problems.
