Spoof attack from everyone inside ???
All Forums >> [ISA Server 2000 Firewall] >> SecureNAT Client >> Spoof attack from everyone inside ??? Page: [1]
Spoof attack from everyone inside ??? - 14.Jan.2002 5:41:00 PM
JayM
Hey I have been running a ISA server for awhile now and everything has been fine, but
I moved to a new server and have been bothered by this problem
All my internial cpu's are spoofing??? and filling up my logs?? Also some machines on
the outside are spoofing like a WINS server and DHCP server????
These machine are not realy spoofing but ISA thinks so???
Please give a clue
ThanX
IP HAS BEEN REPLACED WITH XXX
The message....
ISA Server detected a spoof attack from Internet Protocol (IP) address XXX.XXX.XXX.XXX. A spoof attack occurs when an IP address that is not reachable via the interface on which the packet was received. If logging for dropped packets is set, you can view details in the packet filter log.
RE: Spoof attack from everyone inside ??? - 14.Jan.2002 8:21:00 PM
Hi Jay,
double check your IP numbering (has it changed?) and the LAT on ISA.
(in reply to JayM)
RE: Spoof attack from everyone inside ??? - 14.Jan.2002 8:31:00 PM
JayM
No numbering has changed!
It almost sounds like I have a loop but
thats not the case???
They are going through VLAN's on the same switch but It has not happened in the past.
ThanX
(in reply to JayM)
RE: Spoof attack from everyone inside ??? - 14.Jan.2002 8:36:00 PM
Hi Jay,
WOW... do you trust VLAN for splitting the internal and external interface of ISA? I would never, I repeat NEVER do that for security reasons.
Can you post the ipconfig /all for all adapters and the routing table? Maybe that tell us more...
(in reply to JayM)
RE: Spoof attack from everyone inside ??? - 14.Jan.2002 10:22:00 PM
JayM
I have no fear of VLAN's security this
is a Cisco 6509 switch and we run other campus VLAN's with no problem. You have to make sure of your gateway # and Cisco will
allow other gateway address!
I beleive I solved the problem! I have four
nic's in this box and the two other nic's (not used yet) had got private address and I guess thier was some bleed over in them ???? ; )
ThanX for the time
(in reply to JayM)
