Static NAT ??? not with ISA 2004
Static NAT ??? not with ISA 2004 - 9.Aug.2005 3:54:00 AM
zamirl
Did you ever had the need to completly make a server in your network available to the world or to another network on all ports even if the server is behind NAT ?
Well, I did, or at least I wanted to test it
The only option which seems reasnable to perform this is to create a server publishing rule and to create a protocol definition "all ports" and provide all TCP port range for inbound.
What is the problem ? As soon as you try to apply such a rule the server virtual memory will sky rocket and your server is useless !
To be honest I did not try to do it on a Windows 2003 with SP1 or with SP1 for ISA 2004. If anyone else did try it with service packs and had a different results I would love to read about it.
Liran Zamir
RE: Static NAT ??? not with ISA 2004 - 9.Aug.2005 6:18:00 AM
Hi Liran,
This was an issue identified during the beta phase, and I don't think there are any chances with SPs.
I can't imagine a firewall scenario that would require this type of config. If you need unprotected access to a server, put it on the DMZ in front of the ISA firewall.
HTH, Tom
RE: Static NAT ??? not with ISA 2004 - 31.Aug.2005 6:36:00 AM
Nagorg
My question may not be exactly to the same point as Liran's, but similar. When working with a PIX, you generally create static translations from a public IP to a private IP and associated ACL's. In this configuration scenario, any outbound traffic from the public IP will leave the private network as the configured static public IP address and not what has been configured for use in NAT/PAT. Is there a way to force this in ISA2004? I cant create a route rule because my internal IP is private non-routed IP address. To be more specific, my scenario is with an SMTP server. While I have created a publishing rule the does work for all inbound SMTP traffic, any time my SMTP server actually sends mail, it leaves the network from my NAT'ed address instead of the published IP. How can I control this behavior?
RE: Static NAT ??? not with ISA 2004 - 31.Aug.2005 9:10:00 AM
isawader
ISA doesn't support 1-to-1 NAT from private network to public network. It's been on the wish list for a long time.
A work around involves configuring a "route" Network rule.
