Strange slow file copy speed problem
All Forums >> [ISA 2006 Firewall] >> General >> Strange slow file copy speed problem Page: [1]
Strange slow file copy speed problem - 11.Aug.2008 4:22:06 AM
nsotiriu
We have 2 ISA Firewalls running on DL380G5 wich build a VPN Tunnel through a 4Mbit SDSL connection.
NET1 <=> ISA1 <=> ISA2 <=> NET2
The Problem is i copy a file from a server in NET2 to a Server in NET1 the Performance is quiet bad 600-700 KBit. But if i copy a file from NET1 to NET2 everything is fine.
A direct copy between the two ISA Servers is also fine.
We did some testing with iperf, which shows a 30% lost of packages on the UDP test.
I already did the following:
-Auto Netgotioation changed from AUTO/AUTO to 100Full/100Full on both ISA Servers
-Disabled TOE on both ISA Servers
-Disabled TCP chimney on both ISA Servers
-Disabled RSS on both ISA Servers
-Installed Hotfix KB936594 on both ISA Servers
-Updated the NIC drivers to the last Version
-Updated the NIC firmware to the last Version
More Infos:
DL 380 G5
NIC 373i
Windows 2003 Server SP2 (all Hotfixes)
ISA Server 2006 SP1
RE: Strange slow file copy speed problem - 19.Aug.2008 8:45:31 AM
Make sure you use L2TP/IPsec for the site to site VPN tunnel, or PPTP. IPsec tunnel more has the worse performance.
(in reply to nsotiriu)
