Supernetting + ISA = Possible?
All Forums >> [ISA Server 2004 Firewall] >> Network Infrastructure >> Supernetting + ISA = Possible? Page: [1]
Supernetting + ISA = Possible? - 12.Aug.2004 12:51:00 AM
grinn253
Hello all again "[Smile]"
So I have my normal /24 subnet of public IPs. I now understand that for ISA,
Its virtal that the Internal and external interfaces, and any other interfaces on the ISA firewall, all be located on different network IDs.
I would like to have some of those public IPs remain the same. So i've supernetted:
Original network IP range (/24):
128.208.125.0 - 128.208.125.255
Subnet mask 255.255.255.0
Proposed supernetted network IP ranges(/26):
128.208.125.1 - 128.208.125.63
128.208.125.64 - 128.208.126.127
128.208.125.128 - 128.208.125.191
128.208.125.192 - 128.208.125.255
Subnet mask that applies to the four 'networks' above is 255.255.255.192.
Alas! There are now 4 *different* networks from my original /24 network.
So the question is:
Can ISA route *properly* with a supernetted network? Such that
External NIC1 = 128.208.125.64/26 MASK 255.255.255.192 which encompasses:
128.208.125.65 - 128.208.125.126
Internal NIC2 = 128.208.125.0/26 MASK 255.255.255.192 which encompasses:
128.208.125.0 - 128.208.125.63
Internal NIC3 = 192.168.125.0/24 MASK 255.255.255.0 which encompasses:
192.168.125.0 - 192.168.125.255
The gateway remains (as it should, correct?) in the 'external' network/NIC with IP 128.208.125.100.
Once again, will ISA/Windows know where packets destined to the different supernetted networks belong to which NIC? "[Confused]" All suggestions welcome - even, "I don't knows" "[Big
Thank you all!
Edgardo
[ August 12, 2004, 12:53 AM: Message edited by: grinn253 ]
RE: Supernetting + ISA = Possible? - 12.Aug.2004 5:34:00 PM
Hi Edgardo,
Of course the ISA firewall will! Each NIC is assigned to a different subnet and each subnet is defined as a different network. You can then create Network Rules to control the route relationship between any two networks. You can set a route relationship between them all, or between some of them. You can even set a route relationship between Internal and External if you like.
The good thing is, no matter if you use Route or NAT, the same strong firewall stateful filtering and stateful application layer inspection is applied to all connections moving through the ISA firewall.
(in reply to grinn253)
