System Error Event ID 1003
All Forums >> [ISA Server 2004 General ] >> Installation >> System Error Event ID 1003 Page: [1] 2   next >   >>
System Error Event ID 1003 - 16.Oct.2008 2:13:55 PM
inlining
Just recently started haveing a problem where ourISA 2004 (win 2003 enterprise with SP2) server where it will have a critical errror and restart. The event details are as follows....  This has never happened before and has happened 3 times in the past 2 days.
Source: System Error
Event ID: 1003
Category: (102)
Error code 0000000a, parameter1 00000000, parameter2 d000001b, parameter3 00000000, parameter4 8085addf.
The help & support center info is as follows:
Details
Product:
Windows Operating System
ID:
1003
Source:
System Error
Version:
5.2
Symbolic Name:
ER_KRNLCRASH_LOG
Message:
Error code %1, parameter1 %2, parameter2 %3, parameter3 %4, parameter4 %5.
Explanation
A blue screen (Stop error) was reported. The message contains details about the error. A matching event with Event ID 1001 might also appear in the event log. This matching event displays information about the specific error that occurred.
User Action
No user action is required.
RE: System Error Event ID 1003 - 16.Oct.2008 4:06:55 PM
Rotorblade
Error code 0000000a
The error would indicate that possibly it could be a faulty device driver or something BIOS related. Did you update any device drivers before this happened? Not seeing the specific STOP error and dump logs it would be hard to tell. Possibly bad memory could be the culprit. Have you run a mem test?
HTH
RB
David Melvin
Ohio
(in reply to inlining)
RE: System Error Event ID 1003 - 16.Oct.2008 5:21:16 PM
inlining
Have not changed anything bios or driver related on this box but the BIOS is a few revisions behind. Only major change change has been installation of .Net 3.0 and SP1 for .Net 3.0. Would you suggest updating the BIOS to the current version and any SCSI/RAID controller drivers?
(in reply to Rotorblade)
RE: System Error Event ID 1003 - 17.Oct.2008 1:28:29 PM
Rotorblade
If it was me, I would test the memory first before you try updating anything. If no drivers had been updated lately, then bad memory is probably the cause. Try to find a copy of memtest or download Ultimate  Boot CD (http://www.ultimatebootcd.com/) and run it from the CD.
HTH
RB
David Melvin
Ohio
RE: System Error Event ID 1003 - 17.Oct.2008 2:52:52 PM
inlining
Thank you David, I really appreciate your suggestion.
RE: System Error Event ID 1003 - 20.Oct.2008 4:01:39 PM
gazy007
I have got exactly the same error on one of my Transtec server win2003 isa2004
I have updated everything Transtec have exchanged the server but I still get this error even after bios flash and memory test. I try to find on google any suggestion but no joy??
RE: System Error Event ID 1003 - 21.Oct.2008 10:06:09 AM
Rotorblade
How much memory is installed on the server?
David Melvin
Ohio
RE: System Error Event ID 1003 - 21.Oct.2008 10:38:33 AM
inlining
David, Our server has 1 GB of ram and I've just ordered another 1 GB dimm to install. It's a Dell poweredge 1750 server.
RE: System Error Event ID 1003 - 21.Oct.2008 10:41:17 AM
gazy007
4 GIG memory on this server.
ORIGINAL: Rotorblade
RE: System Error Event ID 1003 - 23.Oct.2008 10:10:16 AM
h1ckman
I am getting this exact error as well.  Started yesterday and has only happend twice so far but in the span of 16 hours.  No changes in the last two days that I know of to the server, Windows 2003 standard SP2.
About 5 days ago we applied 10 Microsoft patches.  I have also contacted IBM support.  They had me run a utility and send them so low level log files.  According to them it is not a hardware issue.
I am thinking its a Microsoft patch.  Just starting to go down that road.  Here are the patches that were applied.
KB957095
KB956841
KB956803
KB956391
KB954211
KB938464
KB951072-V2
KB950974
KB952954
KB951066
bh
RE: System Error Event ID 1003 - 23.Oct.2008 10:13:29 AM
Rotorblade
With 4 gb, by chance do you have the /3GB switch added to the server's boot.ini? Hope not? Please read below:
http://blogs.technet.com/yuridiogenes/archive/2008/08/21/why-3gb-can-negatively-affect-your-isa-server.aspx
That will help.
RB
David Melvin
Ohio
(in reply to gazy007)
RE: System Error Event ID 1003 - 23.Oct.2008 11:17:23 AM
gazy007
I have checked there is no /3gb switch added. but I was receing smtp on Isa and I have disable this rule and It has not rebooted since.
That will help.
RB
RE: System Error Event ID 1003 - 23.Oct.2008 11:46:42 AM
Rotorblade
Low PTE resources will certainly cause some unexpected problems like you’re experiencing.  A reboot would be necessary.  Before you do, you might want to check using Perfmon to see what PTE’s your system has available.  In Perfmon, select the Memory performance group and add the “Free system page table entries couter”. If you’re below 7,000 Windows will become unstable.
HTH
RB
David Melvin
Ohio
RE: System Error Event ID 1003 - 23.Oct.2008 12:35:33 PM
Rotorblade
That could be possibly the case. That’s why it’s always good to test before applying to production servers. Two of ten patches that you referenced I can see possibly causing some issues.
Keep us updated.
RB
David Melvin
Ohio
RE: System Error Event ID 1003 - 24.Oct.2008 3:51:22 AM
gazy007
Is it possible when I look at alerts it shows me my local clients system's Ip address scanning the ports. Most of them do and it creates alert on alert tabs.
Low PTE resources will certainly cause some unexpected problems like you're experiencing.  A reboot would be necessary.  Before you do, you might want to check using Perfmon to see what PTE's your system has available.  In Perfmon, select the Memory performance group and add the "Free system page table entries couter”. If you're below 7,000 Windows will become unstable.
HTH
RB
< Message edited by gazy007 -- 26.Oct.2008 9:24:10 AM >
RE: System Error Event ID 1003 - 27.Oct.2008 5:08:19 PM
gazy007
Does anyone think alert causing server to not to respond and restart and causing this error message. Please advise.
RE: System Error Event ID 1003 - 28.Oct.2008 4:04:57 PM
Rotorblade
Still having issues? Anything is possible but if you're blue screening I would think that your problem is somewhere down in the HAL; faulty device driver, memory etc.... You’re going to have to capture a dump file and look into the problem further to find the fault. Microsoft patches are known to cause some problems but without a little organized troubleshooting and digging into the cause, speculation will get you no where.
RB
David Melvin
Ohio
RE: System Error Event ID 1003 - 28.Oct.2008 4:15:37 PM
SteveMoffat
This issue has been going opn since the 16th of the month, are your users not a little annoyed yet??
If this was my equipment, I would have exported the config & rebuilt the whole box at least by the 20th. If the issue opersisted, then new hardware would be in order.
Just my 2c worth.
Steve
Steve Moffat
Operations Director
Optimum IT Solutions
www.isaserver.bm
Please consider the environment before printing this post.
RE: System Error Event ID 1003 - 28.Oct.2008 4:24:40 PM
Rotorblade
Ditto here Steve……
Gazy,
If you’re still persistent in finding the cause, the Windows Driver Verifier tool is very helpful.
http://support.microsoft.com/kb/244617
HTH
RB
David Melvin
Ohio
(in reply to SteveMoffat)
Post #: 19
RE: System Error Event ID 1003 - 31.Oct.2008 6:08:08 AM
gazy007
Ditto here Steve……
Gazy,
If you're still persistent in finding the cause, the Windows Driver Verifier tool is very helpful.
HTH
RB
Chees Rotorblade I have used windows verifier and everything was ok.
But am I right to install firewall client on users system and disabling removing the tick from webproxy. Or just leave the tick on in web browser (Enable web browser automatic configuration)if I enable it someusers can not access secure site if I remove the tick and it uses client it works fine.
Post #: 20
