TMG Installation failure - fwpkclnt.sys
All Forums >> [Threat Management Gateway (TMG) 2010] >> Installation >> TMG Installation failure - fwpkclnt.sys Page: [1]
TMG Installation failure - fwpkclnt.sys - 26.Jan.2010 12:07:05 PM
jeffd73
Installing it on a fresh install of Server 2008 Standard x64 on a new HP BL460cG6.
The installation did not generate an error, but upon reboot I get a BSOD with the offending file being fwpkclnt.sys. The blue screen appears after login, during the Applying Computer Settings phase.
The system will boot into Safe Mode.
Any insight would be greatly appreciated.
RE: TMG Installation failure - fwpkclnt.sys - 28.Jan.2010 6:56:46 AM
chrislaz
I have had the same issue. I installed TMG on W2K8 R2 and had exactly the same error and symptoms. I then searched around a bit and found a few posts relating this specific BSOD error with a hardware driver issue. I then installed the same software on another server and all worked fine and has been running for 5 days now with no issue. I would check the Windows install as it seems that is where the error lies and not with TMG. Hope this helps.
(in reply to jeffd73)
RE: TMG Installation failure - fwpkclnt.sys - 4.Feb.2010 3:52:33 PM
jeffd73
The problem was an incompatibility with the Symantec EndPoint Protection Network Protection Component. After removing SEP the server booted OK. After installing just the Antivirus/Antispyware component, the server is running OK.
(in reply to chrislaz)
RE: TMG Installation failure - fwpkclnt.sys - 25.Jan.2011 7:36:10 AM
S08639226
ORIGINAL: jeffd73
Mate, you are a legend this solved my issue after 8 hours of straight troubleshooting and was just about to format too!
Shaun Valentic
Network Manager
Coomoora Secondary College
