TMG error in installation
All Forums >> [Threat Management Gateway (TMG) Beta] >> Installation >> TMG error in installation Page: [1]
TMG error in installation - 12.Jun.2008 2:09:56 AM
wise_guy2002n
Hello Dear,
Nice to hear my first post regarding TMG installation error, i am using 2 servers as specified below.
1) Win2k8 Ent RCO (Domain Controller)
2) Win2k8 Ent RCO (Domain Member) & login domain user with local administrator rights,
After the nice selection in TMG installation, i have received errors below,
Setup was unable to install windows optional components. As a result setup cannot continue
Setup failed while writing internal network information to forefront TMG storage
Have any idea about these errors
RE: TMG error in installation - 12.Jun.2008 2:52:41 AM
On the Machine you are installing TMG, it should be a domain member and the account used to install TMG should be logged on as a domain user that has local administrator privileges on the TMG machine.
(in reply to wise_guy2002n)
RE: TMG error in installation - 12.Jun.2008 3:06:22 AM
wise_guy2002n
Thank for the reply
Tarek,
yes TMG server part of the Domain Controller, and login as a domain user with local administrative privileges.
RE: TMG error in installation - 12.Jun.2008 3:42:26 AM
Are you using x86 or x64?
Jason Jones (MVP)
RE: TMG error in installation - 12.Jun.2008 3:51:44 AM
wise_guy2002n
I am using x86
RE: TMG error in installation - 12.Jun.2008 4:51:15 AM
I think from memory you need to use x64, we had lots of problems trying to install it on x86 and used x64 in the end.
Not 100% sure...but this sounds familiar!
Jason Jones (MVP)
RE: TMG error in installation - 12.Jun.2008 6:26:02 AM
wise_guy2002n
I saw TMG installed on 32bit x86 family, i thouhgt is there some thing remaining.
RE: TMG error in installation - 12.Jun.2008 9:47:08 AM
TMG is supported ONLY on x64 system running Windows Server 2008 RTM.
RE: TMG error in installation - 13.Jun.2008 12:28:02 AM
wise_guy2002n
Thanks for supportive reply, ok i understand what is the problem comes, my all systems and OS is 32bit & x86 flavour, is there any x64 OS to test on VMware because i haven't x64 & 64bit flavour.
RE: TMG error in installation - 16.Jun.2008 10:37:25 AM
VMware Server can be installed on a 32bit Host system that supports VT on Intel systems (and I think AMD too) and that will run 64bit guest systems.
If you have a 64bit server, you can install Windows Server 2008 Hyper-V on that and run 32 and 64 bit guests.
