The certificate chain... Edited please read..
All Forums >> [ISA Server 2004 General ] >> Exchange Publishing >> The certificate chain... Edited please read.. Page: [1]
The certificate chain... Edited please read.. - 6.Dec.2004 3:45:00 PM
Zapata
I'm getting this message after following the "Publishing Outlook Web Access (OWA) Sites using ISA Server 2004 Firewalls" at http://www.isaserver.org/articles/2004owapub.html
ISA Server failed to establish an SSL connection with 192.168.0.5. The certificate chain was issued by an authority that is not trusted.
The failure is due to error: The certificate chain was issued by an authority that is not trusted.
I'm in a Edge firewall configuration with Exchange 2003 OWA behind it, i have exported the certificate as told.
Appreciate any suggestions to why this is happening.
Edit: Solved it by Setting SSL authentication, strange why can't i use OWA forms based as recommended?
I also joined the ISA 2004 to the domain, is there a AD policy that i should apply on the ISA after this?
[ December 06, 2004, 06:18 PM: Message edited by: Zapata ]
RE: The certificate chain... Edited please read.. - 6.Dec.2004 9:10:00 PM
paulrobichaux
You can use forms-based auth on the Exchange server or on the ISA box, but not both.
(in reply to Zapata)
RE: The certificate chain... Edited please read.. - 6.Dec.2004 10:25:00 PM
Zapata
Ok, where do i disable Forms based Authetication in IIS?
