The network rules do not allow the connection requested
The network rules do not allow the connection requested - 11.Mar.2008 5:33:39 PM
riaandw
HELP!!! I'm going bald, prematurely, from pulling my hair out!!! Has anyone managed to get TightVNC Viewer running on a ISA protected network to connect to a external PC over the internet without getting the dreaded 0xc0040012 FWXE_NETWORK_RULES_DENIED message as stated below? Denied Connection Log type: Firewall service Status: The network rules do not allow the connection requested. Rule: Source: Internal ( 192.168.16.97:2994) Destination: External ( 165.xxx.xxx.xxx:5900) Protocol: TightVNC TCP:5900 Outbound My client is doing remote support on a variety of systems for their customers, running anything from TightVNC, PCAnywhere and RemoteDesktop. I've tried everything and searched everywhere, but this happens on all 3 of the above mentioned applications from any PC within the ISA protected network trying to connect to standalone PCs connected to the internet. The hardware firewalls on the routers allows for all access, since I'm able to connect to the standalone PC's connectd to the internet from home, with no problem. Any help and hairlotion will be much appreciate. Ciou Riaan
RE: The network rules do not allow the connection reque... - 12.Mar.2008 9:49:53 AM
Rotorblade
Hi, Do you have an access rule configured? Not seeing one in the log information you provided. Is the ISA Firewall or SecureNAT client installed on the PC? RB
RE: The network rules do not allow the connection reque... - 12.Mar.2008 2:59:22 PM
riaandw
Hi, The problem is that I saw that there are no access rule liste. Why I do not know and where to go and define it I do not know either, as the Remote Desktop type calls from inside the ISA to external PCs is currently the only communication that does not show any access rules. When hovering over the status I get a tooltip with the following message: 0xc0040012 FWXE_NETWORK_RULES_DENIED When looking at the network rules, I have the following defined: Network Rule 1 Order: 1 Name: Local Host Access Relation: Route Source Networks: Local Host Destination Networks: All Networkds (and Local Host) Network Rule 2 Order: 2 Name: VPN Clients to Internal Network Relation: NAT Source Networks: External / Quarantined VPN Clients / VPN Clients Destination Networks: Internal Network Rule 3 Order: 3 Name: Internet Access Relation: NAT Source Networks: Internal / Quarantined VPN Clients / VPN Clients Destination Networks: External Hope the additional information helps. Kind Regards, Riaan
RE: The network rules do not allow the connection reque... - 12.Mar.2008 5:08:33 PM
Rotorblade
Hi, quote:
When looking at the network rules, I have the following defined: Right church wrong pew! Network rules is not where you should be. You need to create a Firewall access rule in the ISA’s Firewall policy for VNC access. It looks like you have the protocol defined so all you should need to do is create the access rule. In the ISA’s MMC, click Firewall policy in the left pane then right-click and click New; Access Rule. Follow the wizard: Name; Access rule name, i.e. VNC access Action; Allow This rule applies to; Selected Protocols; click Add and select the VNC out bound protocol you defined This rule applies to traffic from these sources; Click add and select Internal (using a computer set is an option) This rule applies to traffic sent to these destinations; Click add and select External. (using a destination set is an option) This rule applies to requests from the following user sets; The default will be “All Users” but you will need to decide based on your authentication requirement! Click the finish, apply the changes (by clicking the apply button) and your new access rule should be created. You want to make sure that you place the new access rule in the proper firewall order! HTH RB
