There is no way with RPC over HTTP
All Forums >> [ISA 2006 Publishing] >> Exchange Publishing >> There is no way with RPC over HTTP Page: [1]
There is no way with RPC over HTTP - 20.Sep.2008 7:00:47 PM
xus08
Hi everyone,
I have performed an article from Mr Shinder and all protocols is working except RPC over HTTP. There is no way. I have verified the configuration and everything is fine.
I have read the previous posts related to this topic and there are many users with the same problem. It does not look a problem from ISA Server 2006, but RPC over HTTP Proxy service itself, because some users have resolved the problems after removing and reinstalling this service.
I have checked this workaround and it does not work.
On the client computer the browser shows the following error after I try to check the RPC virtual directory:
Error code: 500 Internal Server Error. The request was rejected by the HTTP filter. Contact the server administrator (12217)
I have set the HTTP filter for the RPC over HTTP rule as Mr Shinder describes at the end of this article:
http://www.isaserver.org/tutorials/Publishing-Outlook-Web-Access-Outlook-RPCHTTP-ISA-Server-2006-Firewalls-Forms-based-Authentication-Part4.html
Thank you very much for your answers,
Greetings,
Xus
P.S.: OWA works fine.
< Message edited by xus08 -- 21.Sep.2008 9:36:50 PM >
RE: There is no way with RPC over HTTP - 22.Sep.2008 4:54:51 AM
This is normal, as the HTTP filters remove the GET method which will be used by a standard browser.
You can add the 'GET' method into the HTTP filter on the RPC/HTTP rule for testing and then remove it again later.
Jason Jones (MVP)
(in reply to xus08)
