Tool for internet usage monitoring
All Forums >> [ISA 2006 General] >> General >> Tool for internet usage monitoring Page: [1] 2   next >   >>
Tool for internet usage monitoring - 2.Sep.2008 4:55:11 AM
mrjahnara
      I am monitoring internet usage and generating internet usage report in the ISA Server everyday. But with the ISA report i can see only the top 15 users usage.
     Can any one tell me , is there any other monitoring tool available that can work with ISA server 2006? Please suggest
Regards
Abdul Rahuman.M
RE: Tool for internet usage monitoring - 2.Sep.2008 6:31:55 AM
Check this : http://www.isaserver.org/software/ISA/Reporting/
(in reply to mrjahnara)
RE: Tool for internet usage monitoring - 2.Sep.2008 11:10:23 AM
paulo.oliveira
other option is customize the reports. Go to Reports - on the Tasks choos one of the options and select the Top Users tab.
Paulo Oliveira.
RE: Tool for internet usage monitoring - 3.Sep.2008 2:22:18 AM
mrjahnara
Thanks for all your response. I manage to customize the ISA reports now for many users.
Thanks for the kind support.
Regards
Abdul Rahuman.M
(in reply to paulo.oliveira)
RE: Tool for internet usage monitoring - 4.Sep.2008 1:53:59 AM
varun25
Hi Abdul
How did you manage to do this? Do you get usernames in the report as well or just the client IP addresses?
Varun
RE: Tool for internet usage monitoring - 4.Sep.2008 2:11:11 AM
mrjahnara
Ya i got username ( Domain users) as well as IP Addresses ( other users) in the report.
Regards
Abdul Rahuman.M
(in reply to varun25)
RE: Tool for internet usage monitoring - 4.Sep.2008 2:21:34 AM
varun25
for some reason i dont get usernames in the logs just the client Ip addresses.
Did you create a rule for this? My ISA server is a member of the domain so i havent configured any LDAPS rules.
Can you please assist?
RE: Tool for internet usage monitoring - 4.Sep.2008 2:28:45 AM
mrjahnara
Hi Varun,
I didnt create any rule for this, but all our client Pc's have firewall client installed.
Regards
Abdul Rahuman.M
RE: Tool for internet usage monitoring - 4.Sep.2008 2:37:14 AM
varun25
Is it being used a web proxy in your environment? Do you get web logs as well?
RE: Tool for internet usage monitoring - 4.Sep.2008 4:17:24 AM
ORIGINAL: varun25
To Get usernames in ISA Server reports, you will need to authenticate your users, that is to set them as Webproxy CLients and/or Firewall CLients.
and make sure to remove the condition ALL Users , and replace it with the ALL Authenticate user group or a user/group from AD.
and by the way. LDAP is only used for inbound rules , and not for outbound access policies.
RE: Tool for internet usage monitoring - 4.Sep.2008 4:32:14 AM
stuarta
Sorry to sound stupid, but how would I go about this?  I have the same problem, all my users are only showing IP addresses.  Some usernames appear but the majority is just ip addresses.
(in reply to elmajdal)
RE: Tool for internet usage monitoring - 4.Sep.2008 4:47:40 AM
mrjahnara
If all of your users are Domain users , then u can change the condition All Users to All Authenticated users. you will get username in the report.
Regards
Abdul Rahuman.M
(in reply to stuarta)
RE: Tool for internet usage monitoring - 4.Sep.2008 4:52:18 AM
stuarta
Yep they are all domain users.  I don't see that option anywhere?
RE: Tool for internet usage monitoring - 4.Sep.2008 4:55:11 AM
stuarta
Ah,
In my 'unrestricted internet access rule' I have the condition 'all users'.  I've just added 'all authenticated users' as well.
But would that grab and list every username that goes on there?  Don't obviously want it to miss anyone out.  I'm guessing this is also now going to show this on the live logs as well and my stream out to my MSDE logs?
RE: Tool for internet usage monitoring - 4.Sep.2008 5:25:59 AM
stuarta
ok just noticed that with both of them in there, I still get anonymous.  I removed 'All Users' and it showed the domain user name but their access stopped.
I'm guessing therefore that my users aren't being authenticated.  How should I check this or set it please?
RE: Tool for internet usage monitoring - 4.Sep.2008 7:43:06 AM
stuarta
Sorry adding to this yet again, I've found a post saying that I need to alter my internal network authentication from Integrated to Basic.
Want to make sure that switching isn't going to effect anything else or just whether switching on basic in addition to integrated would help.
Did notice a warning when clicking on basic in addition saying
"The authentication method you have selected results in passwords being transmitted over the network without data encryption.  An intruder attempting to compromise your system security could use a protocol analyser to examine user passwords during the authentication process"
RE: Tool for internet usage monitoring - 4.Sep.2008 8:57:04 AM
That's true. Basic credentials are sent in the clear, which means anyone with a network sniffer will be able to read them.
RE: Tool for internet usage monitoring - 4.Sep.2008 8:59:16 AM
stuarta
ok thanks.  So how can I ensure that all the users are authenticating in order to get internet access?  They are authenticating ok for activesync and OWA, but not general internet access.
RE: Tool for internet usage monitoring - 4.Sep.2008 10:49:16 AM
paulo.oliveira
first your users/machines must be on the same domain as ISA server. After that, you have to make sure that your users are logging into their machines using the domain accounts.
If all these requirements are OK, then it should work.
Paulo Oliveira.
Post #: 19
RE: Tool for internet usage monitoring - 4.Sep.2008 11:02:48 AM
stuarta
yep, I can put a tick in all of those boxes.  All machines are on the same domain, and on the same network
Post #: 20
