Transparent Proxy with WebSense
All Forums >> [ISA Server 2004 Firewall] >> HTTP Filtering >> Transparent Proxy with WebSense Page: [1]
Transparent Proxy with WebSense - 20.Nov.2006 1:26:20 AM
progzoom
Dear all,
Does anybody know how to configure a transparent proxy (Once user connected to the server, he does not need to put proxy server into the web browser) server with integration with Websense web filter?
Since currently I have installed the websense and configured the proxy, under the ISA management > Configuration > Add-Ins > Web Filters , I can see "WsISAFilter" added. But just that if the proxy is not typed in the web browser, I still can go through some pornographic web pages.
Any ideas to the problem?
Thank you very much in advance!
Joe Chan
RE: Transparent Proxy with WebSense - 4.Jan.2007 1:22:35 PM
abqtech
I'm running ISA 2004 with Websense (but not as a transparent proxy)  By transparent proxy I assume you have routing setup in your network that routes all HTTP based traffic (route based upon Destination Ports 80, 443, etc..) to your ISA Proxy server.
Have you looked at setting up WPAD? (closest thing to a transparent proxy, that I'm aware of) but needs to run in a windows environment.  I think that a Transparent Proxy and Proxy integration with Websense are two seperate things, and therefore should be addessed individually.
Are you saying that if you don't set any proxy settings in the browser, you can access content that should be filtered by Websense?  Are you certain that the requests are being proxied by ISA.  (by way of logging/monitoring the traffic, from ISA, to confirm that it's indeed going through ISA?)  I ask because your relying on the routing of your network to send the traffic to the proxy, and you have not provided much information regarding the setup of you transparent proxy architecture.
I'll try to help you out, but it may take a few posts.
(in reply to progzoom)
RE: Transparent Proxy with WebSense - 4.Jan.2007 9:16:56 PM
progzoom
Dear abqtech,
Thank you for your reply and kindly help. Please see my replies:
[progzoom] Yes, I set the gateway of the clients' machines to be the IP of the ISA server.
[progzoom] Could you provide more details on WPAD? Is that a separate product or built-in already in ISA?
[progzoom] Yes, I can still access those non-80 port traffics. The WebSense can block those 80 port traffics.
[progzoom] From logging/monitoring, I can see those non-80 port traffics, thus I assume the ISA should handle them but just don't pass those traffics to the WebSense Add-In
[progzoom] Surely no problem, your kindly help is much appreciated.
(in reply to abqtech)
RE: Transparent Proxy with WebSense - 5.Jan.2007 3:19:34 PM
abqtech
For more on WPAD see: http://www.microsoft.com/technet/isa/2004/plan/automaticdiscovery.mspx
What does your Websense implementation look like?
...For example is your websense server on a different host than your ISA Server?  Is the websense Filtering Service & Filtering Plug-in installed on your ISA Server?  How is websense integrated a How have you configured objects within ISA and what ISA Access rules are configured to allows traffic to Websense?  By default the websense block service runs on TCP 15871 on your ISA Server, have you configured an access rule to allow that?
What Network Agents (IP Subnets) are configured withing the WebSense?
Are you running ISA 2004 Standard or ISA 2004 Enterprise?
What version of Websense are you running?
What application and web filters are enabled within ISA?
RE: Transparent Proxy with WebSense - 6.Jan.2007 9:45:57 AM
tonygauderman
If your users are in an Active Directory environment, use GPO's to define the proxy server and prevent users from changing it.
RE: Transparent Proxy with WebSense - 10.Dec.2007 5:10:54 AM
PeteSt
Hi abqtech,
You really seem to have a good handle on Websense with ISA.  I have just configured this at my work.  I enabled port 15871 & 15868 outbound local host/internal to internal, and it appears to work fine.  Can you tell me if this is all the rules required for ISA integration with Websense..?
Thanks in advance,
Pete
(in reply to tonygauderman)
RE: Transparent Proxy with WebSense - 27.Dec.2007 1:35:14 PM
abqtech
The Websense plug-in traffic communicates over TCP Outbound 15868
The Websense filtering traffic communicates over TCP Outbound 15871
The Websense Policy Server traffic communicates over TCP Outbound 30600, 30602, 40000,55805,55806
And should be accounted for in a All Users rule that allows source and destionation as the Internal IP's of your ISA Servers (assuming you have an array in ISA 2006 EE) and Websense server.
(in reply to PeteSt)
RE: Transparent Proxy with WebSense - 27.Dec.2007 1:39:02 PM
abqtech
after further thought on a "transparent proxy" I believe in ISA vernacular Secure NAT should be interchangeable with transparent proxy, anyone care to comment?
