Tri-Homed DMZ Without Public IPs
All Forums >> [ISA Server 2000 Firewall] >> DMZ >> Tri-Homed DMZ Without Public IPs Page: [1]
Tri-Homed DMZ Without Public IPs - 7.Jan.2005 7:54:00 PM
smokeskull
As an FYI, it is possible in ISA 2000 to make a tri-homed DMZ using private IP schemes in the DMZ With 3 NICs; NIC1 to internet, NIC2 to DMZ, NIC3 for private network. The way you make it so that all the traffic between the private network and the DMZ is routed over the external interface and filtered by the FW is as follows:
1. Set up the ISA server LAT normally.
2. Set the internal DMZ interface and network to a different private subnet than the internal LAN interface's private subnet.
3. In the RRAS console on the ISA server, go into IP routing. Open the properties of the internal LAN NIC. Add an incoming and an outgoing filter that stops all traffic coming and going to the DMZ subnet. Wait a few minutes for the connections to die out.
That's it! Now all traffic to and from the DMZ will have to use the external interface and all the rules configured there. So, make sure your internal DNS is pointing at the correct IP!
