Tri-homed server and routing from internal lan to DMZ
All Forums >> [ISA Server 2000 Firewall] >> DMZ >> Tri-homed server and routing from internal lan to DMZ Page: [1]
Tri-homed server and routing from internal lan to DMZ - 30.Jul.2002 3:48:00 PM
Yan
I have tri-homed computer between an external network, DMZ and internal network. I want to allow routing between internal network and DMZ, or at least make servers in DMZ accessible from internal network.
Packet filter will not allow me to create this filter.
IP Protocol filter only allows client protocols, not allowing to select destanation.
Can I create this filter or ISA can't this?
Yan
RE: Tri-homed server and routing from internal lan to DMZ - 30.Jul.2002 3:59:00 PM
Yan
sorry:
Protocol Rules only allows protocols, not allowing to select destanation.
(in reply to Yan)
RE: Tri-homed server and routing from internal lan to DMZ - 30.Jul.2002 7:33:00 PM
Hi Yan,
To learn more about the different DMZ scenario's, check out:
- http://www.isaserver.org/pages/articles.asp?art=37
- http://support.microsoft.com/default.aspx?scid=%2Fservicedesks%2Fwebcasts%2Fwc110801%2Fwcblurb110801%2Easp
The DMZ subnet is considered by ISA as an external interface. So, to access from the inside servers on the DMZ, use the regular protocol and site&content rules. Also, to let DMZ servers have inbound access, use the regular publishing rules to publish services on the DMZ interface.
(in reply to Yan)
RE: Tri-homed server and routing from internal lan to DMZ - 30.Jul.2002 8:57:00 PM
Yan
Thank you.
Can I use protocol rules with select destination (non http/ftp protocol)? I see, what i can define destanations only for http and ftp (for ftp over http-proxy) protocols.
I want give access from server in internal network to server in DMZ, but only to it. It's possible?
(in reply to Yan)
RE: Tri-homed server and routing from internal lan to DMZ - 30.Jul.2002 11:50:00 PM
Hi Yan,
ISA's outbound access control is based on protocol and site&content rules. Basically a client is granted/denied access to a service with a protocol rule and to a destination with a site&content rule. However, in the current release of ISA you cann't control for which destinations a client may use a particular protocol.
So, you need to define a site&content rule with a destination set containing your DMZ server and who applies to the internal server (client set or user/group).
(in reply to Yan)
RE: Tri-homed server and routing from internal lan to DMZ - 31.Jul.2002 8:40:00 AM
Yan
You were writing about the "current release". Do you know when the next version will be available and whether it will have that capability?
(in reply to Yan)
RE: Tri-homed server and routing from internal lan to DMZ - 31.Jul.2002 2:28:00 PM
Hi Yan,
noop, I don't. But feel free to add your suggestions in http://forums.isaserver.org/ultimatebb.cgi?ubb=forum;f=18
(in reply to Yan)
