TriHomed ISA - Question
TriHomed ISA - Question - 8.Oct.2004 10:32:00 AM
**P.Gordon**
Here's a question: I am using ADSL for inbound\outbound web Nic #1 Internal card = Nic #2 Here is the question - can I have a Nic #3 configured with external IP (no gateway) (SDSL connection) this would be used for the Site to Site VPN link.
If I can achieve this how do I tell ISA to use this card as a route for the VPN
I hope I made sense,
Regards Pete
RE: TriHomed ISA - Question - 8.Oct.2004 11:17:00 AM
Hi Pete,
You can create a site to site link using the third card. Make sure the static routes are correctly configured.
HTH, Tom
RE: TriHomed ISA - Question - 8.Oct.2004 1:04:00 PM
**P.Gordon**
Many thanks for you reply,
can I tax you for a more specific reply, I am unsure as to how I create the new network to use for the site to site VPN. When this network is created would this then create the route with which to use?
Many thanks Pete
RE: TriHomed ISA - Question - 8.Oct.2004 8:03:00 PM
snojslky
You need to add a route that tells the you server that that it should use your SDSL nic for the vpn site you are connecting to.
route add x.x.x.x mask x.x.x.x z.z.z.z -p
x.x.x.x the ip of the external vpn site z.z.z.z the isp gateway for you SDSL
/Snoj
RE: TriHomed ISA - Question - 11.Oct.2004 5:37:00 PM
**P.Gordon**
Thanks for you reply. I feel I did not make my self entirely clear. I understand the method with which to create a static/persistant route.
To add the SDSL network into ISA do I have to add as a perimeter network?
Also is I do then how do I configuer VPN in ISA. I beleive when I create the VPN it will create the routing table at this point as I would tell ISA what the remote internal network address range is.
The reason I am question the method to create the VPN is because when I have my three NIC's all enabled and ICMP set to reply I can get no reponse from the SDSL Nic unless I disable the ADSL (Internet) external NIC.
Thanks Peter
RE: TriHomed ISA - Question - 19.Oct.2004 9:31:00 PM
anorak
hi. I am also working on the same problem - isa2004. nic#1 - 2mb adsl internet nic#2 - internal nic#3 - dedicated 256k leased line i want my site to site vpn connection to use the leased line and everything else e.g client vpn,www,mail,web publishing etc to use the adsl connection. everything worked fine with only 2 nics. I added the third nic. Then I found couldnt connect a vpn client into the server on nic#1 anymore (error:username or password is invalid on the domain - strangely this then seemed to happen also when you tried to terminal serve to the isa server from within the LAN) I added an additional external network in ISA with the range assigned from my isp on the leased line and changed vpn in isa to allow inbound connections from both nic#1 and nic#3. I also added a route to isa server for remote gatewate for site to site via nic#3 (well the router it is connected to's ip). Still no joy. So what did I miss, how exactly do i make this work?
RE: TriHomed ISA - Question - 20.Oct.2004 4:17:00 PM
anorak
ok - i have got vpn "old" vpn connections working to nic#1 again - i changed the binding order of the nics as it appeared that the newly added nic (#3) had become the first in the list. Still can get any vpn connections (or other traffic) out through the 3rd nic. If i add a static route out to an external ip through the interface I just receive destination network unreachable error?
anorak
