Trihomed DMZ and Web site publishing
All Forums >> [ISA 2006 Firewall] >> DMZ >> Trihomed DMZ and Web site publishing Page: [1]
Trihomed DMZ and Web site publishing - 14.Oct.2010 4:07:24 AM
neilbarker
I am running ISA 2006 in a Trihomed DMZ fashion. I have one website published and using an SSL certificate.
The website is https://www.neilsupport.com and the certificate has the same name. All is working on this site. www.neilsupport.com resolves to 77.88.99.123 and the internal webserver is 11.1.0.1
I want to add another website on a separate webserver 11.1.0.2 called https://test.neilsupport.com which I have setup a DNS record on 77.88.99.124
My router is 77.88.99.1 and I have 4 external IP addresses, 2 as per above.
My question is can I use the same certificate for SSL connections to the second website as I have on my first site or do I need a new certificate?
Thanks in advance
RE: Trihomed DMZ and Web site publishing - 17.Oct.2010 11:13:04 AM
pwindell
No.  You would need a new Cert for "test.neilsupport.com".  The spellings have to match exactly.
The other option is to use a Wild Card Certificate for "*.neilsupport.com"
An additional option os one of the other Certs designed for multiple sites that have a list of allowed sites within them.  I think they are called SAN Certificates, but I'm unsure,...I've always had a mental block for some reason on what they are called,..must be genetic or something.
Phillip Windell
(in reply to neilbarker)
RE: Trihomed DMZ and Web site publishing - 17.Oct.2010 11:30:23 AM
neilbarker
Hi Phillip,
Thanks for the reply, I thought as much.
I have now got a certificate for the test.neilsupport.com domain and have been trying to install it on the ISA server to use with a new web listener to point incoming traffic to the correct web server.
I do however have a problem whereby the certificate is not valid for selection when I try to use it. The original certificate is valid so I must have done it right for the first webserver but not for the second.
I have installed the new cert on the ISA server so what am I missing?
I did the cert request from the actual web server and not the ISA server. COuld that be the problem?
Thanks in advance.
Neil
(in reply to pwindell)
RE: Trihomed DMZ and Web site publishing - 18.Oct.2010 9:13:56 AM
pwindell
The request is done at the web server and it is installed on the web server first.  Then export it at the web server as a PFX file with private key.  Copy the file to the ISA/TMG and import it into the store.
Phillip Windell
RE: Trihomed DMZ and Web site publishing - 18.Oct.2010 9:28:13 AM
neilbarker
Thanks Phil, I thought that might be the case when the ISA server was moaning about the cert there was an error denoting invalid private key.
I exported from the web server and imported on the ISA server and all is now working.
Many thanks,
Neil
RE: Trihomed DMZ and Web site publishing - 21.Oct.2010 9:11:30 AM
pwindell
Very good Neil, glad it worked out.
Phillip Windell
