Trust relationship
Trust relationship - 19.Jul.2007 6:10:38 AM
XP_2600
I want to establish a trust relashionship between two domains, so i need to publish both of the domains, i find an article with the ports which need to be opened but its didn't help maybe cause of udp packets which i dont know if it should be send/receive or send only or what, so if there is a clear guide to how to publish domain controllers for publishing over ISA, it will be something so great, thanks all.
RE: Trust relationship - 27.Jul.2007 11:58:39 AM
You can't publish domain controllers. You'll have to use Access Rules. There must be a Route Relationship (not NAT) between the DCs you want to communicate through the ISA Firewalls. HTH, Tom
RE: Trust relationship - 28.Jul.2007 7:41:38 AM
XP_2600
Thanks so much, i used site to site VPN and applied routing between the two sites ,thanks to ALLAH its worked fine, thanks so much man.
< Message edited by XP_2600 -- 28.Jul.2007 7:42:50 AM >
