Tutorial on setting up Tri-Homed ISA2004 ?
Tutorial on setting up Tri-Homed ISA2004 ? - 10.Mar.2004 12:07:00 PM
AgentASP
Hi
Does anyone have a tutorial on how to setup ISA 2004 on a Windows server 2003 with 3 Nic's, I have several public IP's and would like to publish websites that need access to SQL servers. My idea was to put the webserver (and maybe email server?) in the DMZ and the SQL server in the LAN. Any help would be greatly appreciated. Thanks [ March 10, 2004, 12:09 PM: Message edited by: AgentASP ]
RE: Tutorial on setting up Tri-Homed ISA2004 ? - 10.Mar.2004 3:55:00 PM
Hi Agent,
I haven't done one on this yet, but I'll put it on the list. I've noticed a few people mention this one, so I'll move it up on the list.
Thanks! Tom
RE: Tutorial on setting up Tri-Homed ISA2004 ? - 10.Mar.2004 6:12:00 PM
AgentASP
RE: Tutorial on setting up Tri-Homed ISA2004 ? - 11.Mar.2004 12:16:00 AM
Lambera
I have one but because of an NDA I cant post it but, its not to hard if you are fimilar with ISA 2004.
Use the 3 leg network template. Have 3 netowork cards : Internal, 3rd leg, external, pick a policy and create additonal access policies as needed. Also read Toms other guide on deploying an Edge Tempalte works just about the same.
AJ
RE: Tutorial on setting up Tri-Homed ISA2004 ? - 11.Mar.2004 11:12:00 AM
Hey guys,
One thing worth mentioning is the routing relationships set by the Network Rules by the trihomed DMZ template.
I've recommended to them that they change this so that the DMZ->External is NAT and the DMZ->Internal is Route. Right now, the template sets it up as:
DMZ->External = Router DMZ->Internal = NAT
The template's default depends on you using public addresses in the DMZ, which is less likely than using private addresses.
HTH, Tom
RE: Tutorial on setting up Tri-Homed ISA2004 ? - 6.Oct.2004 7:18:00 AM
arburns
I have setup this scenario but cannot get DNS or ping to work from the DMZ to the Internal LAN even after creating thr rules. Ideally I want to be able to allow all traffic from the DMZ to the internal Network is this possible and how.
I realise the security implications but this is just fro testing
Adrian
