Two Internal networks with AD
Two Internal networks with AD - 8.Sep.2005 5:18:00 PM
curruscanis
I am trying to figure out a method in a lab enviorment two protect a very secure network with a ISA 2004 Firewall.
My lab is setup with a ISA firewall with three interfaces: Internal / Servers Network <- secure network with Active Directory Domain controllers and other servers.
Internal / Client Network <- internal network consisting of client pc's, and other misc.
External / internet <- the internet
I am trying to setup an enviorment that will allow the client PC's that are in the second internal network to access the secure internal network only if they are members of the domain.
I have attempted installing the Firewall Client on the clients and setup an "Allow all traffic" policy between the two internal networks with the condition that the "user" must be a domain user. The ISA firewall is also a member of the Domain, allowing the creation of a domain users group identity. This so far has proved unsuccessfull as the clients attempting to connect, with or without the firewall client, do not seem pass their username credentials for access other than HTTP/HTTPS.
How do I get the clients to send their username credentials for access to ports other than HTTP? So that my clients on a different interface than my servers can authenticate and send data back and forth.
Thanks in advance... beer to the successful assistance!
RE: Two Internal networks with AD - 12.Sep.2005 9:40:00 AM
Hi Currus,
You can't force authentication for intradomain communications, because the Firewall client must be able to communicate with the DC. Once authenticated, then the user can be auth'd for all other communications.
HTH, Tom
RE: Two Internal networks with AD - 12.Sep.2005 11:53:00 AM
curruscanis
Thank you Tom, does that mean if I have a domain controller in the Internal Client Network that my clients can authenticate to it and then have pass through authentication using the firewall client from then on? Using all TCP / UDP ports?
It would seem from this, that I will have to use a dynamic VLAN technology like Cisco to acomplish my goals instead of ISA server.
To clarify I am attempting to secure a wired building from people plugging in that are not members of a domain. I still want to give them guest access ( internet, possible access to pubilic resources. ) but no direct secured access.
