Two SSL Listeners
All Forums >> [ISA Server 2004 General ] >> Web Publishing >> Two SSL Listeners Page: [1]
Two SSL Listeners - 25.Sep.2007 6:04:18 AM
landoa
Hello,
I would like to setup a second SSL listener.  The first is already setup for OWA, which is defined for the Internal network (IP address of ISA 2004), and the second will be for OMA.  I have two public IP addresses, one for OWA and one for OMA.
I understand that there can only be one listener per IP/port.  Do I have to define the two public addresses on the NIC of ISA 2004?  How can that be done?
Thanks alot.
RE: Two SSL Listeners - 26.Sep.2007 11:46:20 AM
davidwmjones2
Start - Settings - Control Panel - Network Conenctions
Select properties on the network connection
Select IP Protocol, properties
Where you select the IP protocol to set the first IP address. Select the 'advanced' button where you can set several extra IP addresses on the same card, by clicking the 'Add' button.
Note, the add button is greyed out if you use DHCP to set the ip address.
This should work for all Windows servers/workstations.
(in reply to landoa)
RE: Two SSL Listeners - 27.Sep.2007 10:30:41 AM
landoa
ISA 2004 is in the domain, and has a private address behind the router.
So, any address added to the NIC would be considered a "Virtual IP"?  I assume that these additional addresses would have to be private addresses as well, with traffic forwarded to them by the router/firewall that manages NAT?
Thanks again.
(in reply to davidwmjones2)
RE: Two SSL Listeners - 3.Oct.2007 8:36:03 AM
enricoklein
If the ISA server is secured from the internet by a NAT device, then you would need to do some configuration on the external NAT device to forward connections for those two IP's to 2 private adresses. Add these private addresses to ISA and setup the listeners to listen on these addresses.
I think that should work :D
Kind regards,
Enrico
