URL Set <> DNS problem
URL Set <> DNS problem - 6.Dec.2005 11:00:27 PM
hellie_vti_1979
Hi, Here is my network situation ----internet----cable modem-----router------isa 2004 server-----gigabit switch connected with fileserver and clients My isa 2004 server has 2 nics 1 connected with the router 1 connected with the gigabit switch The clients can all perfectly browse the internet. DNS Server has the forwarders of oure ISP. Now i want to block some website's. I created a new URL set with the sites i wanted to block. After that i created a new access rule with the URL set. Then i tried a client which all have the Firewall Client installed and i could reach the website specified in the URL set. (bad) When i enter the IP address in the URL set the client cannot reach the website what is i want to accomplish. When i run a command prompt on the client and execute a nslookup to a domain i get the correct ip. I don't want to enter the IP of the site i want to block in the URL set offcourse. Anyone any suggestions? What do i have to check first? I'm pretty sure my dns server works. The nslookup proves this?? Thanks
RE: URL Set <> DNS problem - 7.Dec.2005 12:05:35 AM
Sunny.C
HMMmmm Can you write out what your rule looks like please. Should look like... example: Action=Deny, Protocols=http,https, From/listener=internal, To=*.spyware.com , Condition=all users
RE: URL Set <> DNS problem - 7.Dec.2005 8:09:41 AM
hellie_vti_1979
ORIGINAL: Sunny.C HMMmmm Can you write out what your rule looks like please. Should look like... example: Action=Deny, Protocols=http,https, From/listener=internal, To=*.spyware.com , Condition=all users My rule is on top and is exactly like the rule above. Except the "all users" is replaced with "authenticated users". When i enter the IP address in the URL set it works, if i set the full domain name it doesn't work.
RE: URL Set <> DNS problem - 12.Dec.2005 6:25:53 AM
Sunny.C
Can you ping the sites using the full name??? How is your dns configured on your clients end??? Try set the rules to all users instead of authenticated users.
RE: URL Set <> DNS problem - 12.Dec.2005 10:28:57 AM
hellie_vti_1979
ORIGINAL: Sunny.C Can you ping the sites using the full name??? How is your dns configured on your clients end??? Try set the rules to all users instead of authenticated users. i cannot ping the full name cause the ping command is blocked in the router. when i try to ping for example www.google.be it resolves directly the dns name to 64.233.183.104 oure Domaincontroller is also the DNS server. The clients have the ip from the DC as first DNS I changed the rule to all users instead of auth. users but with the same result.
RE: URL Set <> DNS problem - 13.Dec.2005 12:10:46 AM
Sunny.C
So if you block 64.233.183.104 it works???? but not if you use www.google.be???? Do you have a rule for your internal dns server access out to external??? Do you get any errors in the logs?
RE: URL Set <> DNS problem - 13.Dec.2005 12:35:19 AM
You need to use the web proxy client to allow this type of rule to work - this way, ISA will do the DNS lookup and hence be able to match the URL set correctly. I am guessing at the moment that you are just pointing your default gateway to the ISA firewall and hence you only have SNAT client. Therefore, if the client does the DNS request on its own, it will then ask ISA to connect to the IP and hence your ruleset will need to have IP's not names. Configure your IE settings to use a proxy server and then test the URL sets again - it should now work! Check out the articles on this website about different client types and the best ones to use... HTH JJ
RE: URL Set <> DNS problem - 18.Dec.2005 2:34:07 PM
hellie_vti_1979
ORIGINAL: Sunny.C So if you block 64.233.183.104 it works???? but not if you use www.google.be???? Do you have a rule for your internal dns server access out to external??? Do you get any errors in the logs? If i block 64.233.183.104 it works, if i block www.google.be it doesn't I have a rule for my internal dns server to access out to external: rule: allow dns query server > allow > dns & http > from/listener (computer: internal dns server) > to external > condition (administrators, all users, authenticated users) don't see any errors at this moment
RE: URL Set <> DNS problem - 18.Dec.2005 2:42:27 PM
hellie_vti_1979
ORIGINAL: Jasonjo You need to use the web proxy client to allow this type of rule to work - this way, ISA will do the DNS lookup and hence be able to match the URL set correctly. I am guessing at the moment that you are just pointing your default gateway to the ISA firewall and hence you only have SNAT client. Therefore, if the client does the DNS request on its own, it will then ask ISA to connect to the IP and hence your ruleset will need to have IP's not names. Configure your IE settings to use a proxy server and then test the URL sets again - it should now work! Check out the articles on this website about different client types and the best ones to use... HTH JJ Thanks for the information. IP configuration f.e. DNS Server: IP:192.168.1.1 Smask: 255.255.255.0 GW: 192.168.1.4 1st DNS: 192.168.1.1 And forwarders installed @ DNS conf. ISA Server: IP: 192.168.1.4 Smask: 255.255.255.0 no gateway 1st DNS: 192.168.1.1 Client Computers: IP: 192.168.1.100 Smask: 255.255.255.0 no gateway 1st DNS: 192.168.1.1 All the client computers have the Firewall Client installed. Configuration Internet Explorer: The Use of a proxy server: 192.168.1.4 port 8080 is checked Do not use proxy server for internal addresses is checked
RE: URL Set <> DNS problem - 18.Dec.2005 11:34:57 PM
hellie_vti_1979
I discovered something new: I looked at the logging feature in ISA2K4 I entered www.google.be on a client and looked at the log. The connection was allowed but in the last column where the URL is stated i see: http://66.249.93.104/ So i doesn't show http://www.google.be Right under that rule i get 2 DNS requests 1 from the ISA server to the internal DNS server 1 from the Internal DNS server to External both are allowed
RE: URL Set <> DNS problem - 19.Dec.2005 10:18:41 PM
hellie_vti_1979
ORIGINAL: hellie_vti_1979 I discovered something new: I looked at the logging feature in ISA2K4 I entered www.google.be on a client and looked at the log. The connection was allowed but in the last column where the URL is stated i see: http://66.249.93.104/ So i doesn't show http://www.google.be Right under that rule i get 2 DNS requests 1 from the ISA server to the internal DNS server 1 from the Internal DNS server to External both are allowed looks like this is resolved
RE: URL Set <> DNS problem - 20.Dec.2005 4:51:47 PM
hellie_vti_1979
ORIGINAL: Jasonjo and the solution was???... i don't have a solution for the main problem. i quoted another problem that has been resolved. But i still can't block url's. Only IP addresses.
RE: URL Set <> DNS problem - 20.Dec.2005 9:17:05 PM
hellie_vti_1979
i noticed some "dnsapi" errors in the system log of the isa server The system failed to update and remove pointer (PTR) resource records (RRs) for network adapter with settings: Adapter Name : {adapter_ID} Host Name : < host_name> Adapter-specific Domain Suffix : DNS server list : 192.168.1.1 Sent update to server : 255.255.255.255 IP Address : 192.168.1.4 The system could not remove these PTR RRs because the update request timed out while awaiting a response from the DNS server. This is probably because the DNS server authoritative for the zone that requires update is not running. maybe this is a possible reason. i keep searching
RE: URL Set <> DNS problem - 20.Dec.2005 10:51:54 PM
hellie_vti_1979
i'm really freaking out now: i created a new URL Set i add a website to the URL set >> http://vtm.be i try it on a client and the ISA server blocks the site perfectly. I monitor it on the ISA machine and the rule is working perfect. i add another website to the URL set >> http://vrt.be i try it on a client and it doesn't block the site. so what the hell?
RE: URL Set <> DNS problem - 20.Dec.2005 10:56:30 PM
hellie_vti_1979
ok it works if i enter http://*.vrt.be so problem resolved
