URL Sets
All Forums >> [ISA 2006 Publishing] >> Web Publishing >> URL Sets Page: [1]
URL Sets - 3.Nov.2008 3:39:35 PM
cytex
Hi i'm trying to setup ISA to only allow one URL set with the url http://***/Page.aspx?id=432 I have exactly use the url with Page.aspx?id=432. Does ISA support URL sets direct to asp/aspx sites? Using ISA Server 2006 Standard.
RE: URL Sets - 15.Nov.2008 7:51:06 AM
Yes, you can do that.
(in reply to cytex)
RE: URL Sets - 15.Nov.2008 8:44:51 AM
cytex
Okey but the question is how? It wont help if I just add the URL to the URL set. Is there any more feature to handle asp/aspx sites with ?id=number.
RE: URL Sets - 17.Nov.2008 8:22:55 AM
If you can't add the URL to the URL set, how do you expect to add it to the URL set?
(in reply to cytex)
RE: URL Sets - 17.Nov.2008 10:12:05 AM
cytex
Hi
I can add it as URL set but i wont allow me to access the site. My first though was that it don't can handle aspx url's with id. I must have the ?id=432. If i change the URL set to page.aspx I can access the mainpage without problem but I only want users to access the site with id=432.
RE: URL Sets - 19.Nov.2008 9:45:09 AM
I see. That's true that you can't set a set to a query, since that's not the actual page they're going to, so the firewall won't recognize that as the page the user is actually going to.
(in reply to cytex)
RE: URL Sets - 28.Nov.2008 8:09:11 PM
cytex
Ok thx for the help :)
