URL not showing in logging
All Forums >> [ISA 2006 General] >> General >> URL not showing in logging Page: [1]
URL not showing in logging - 19.Aug.2008 10:34:10 AM
teejayuu
Hi
ISA Server 2006 Standard with XP clients.
I have just noticed that my Internet Access rule has stopped showing the URL's that the users have accessed in the logging tab.  Any ideas?
Action: Allow
Protocols: HTTP, HTTPS, FTP
To: External
User: All Users
The ISA server is on a domain and is used (at the moment just as a web proxy).  I have also noticed that user names are appearing as HomerS (?)
Tony
RE: URL not showing in logging - 19.Aug.2008 6:16:32 PM
Have you recently started using the Firewall client by any chance?
The 'username (?)' entries show that users are using the firewall client but the ISA rules are not configured to specifically require authentication.
Jason Jones (MVP)
(in reply to teejayuu)
RE: URL not showing in logging - 20.Aug.2008 3:14:08 AM
teejayuu
Hi Jason and thanks
I have just installed firewall client, but on my machine only, and I have my rule allow All Users and All Authenticated Users.  This is only as a test.  When I get it working then I will remove All Users.
I am more concerned as to why nothing is showing in the URL or Referral Server columns when I am monitoring the rule.  I there some setting I have missed?
Tony
RE: URL not showing in logging - 21.Aug.2008 8:48:53 AM
Make sure that the Firewall client settings configure the Web Proxy client configuration on the client machines.
RE: URL not showing in logging - 26.Aug.2008 8:03:15 AM
paulo.oliveira
Hi Tony,
Action: Allow
To: External
User: All Users
are you using a single NIC? If so, you have to create access rules from Internal to Internal.
Paulo Oliveira.
RE: URL not showing in logging - 26.Aug.2008 9:18:27 AM
Hi Paulo,
Good point. Since there isn't any external network, rules are always made from internal to internal.
(in reply to paulo.oliveira)
RE: URL not showing in logging - 26.Aug.2008 5:16:40 PM
You've said :
Then you already having successful outbound connection, but ur issue is with the logging ? right ?
Check Tom's Article : How to Record URL and User Information in ISA 2004 Firewall Logs and Reports
 >>> Also check this : Troubleshooting: ISA Server Reports Show No Traffic
Tarek
RE: URL not showing in logging - 28.Aug.2008 8:29:46 AM
Hi Tarek,
(in reply to elmajdal)
