UTF-8 compression
All Forums >> [ISA Server 2004 Firewall] >> HTTP Filtering >> UTF-8 compression Page: [1]
UTF-8 compression - 17.May2006 9:17:07 AM
ThatOtherGuy
I have read some posts on my question, but have not found a solution yet.
Before I installed SP2 with the HTTP filter fix, I was not able to access a site www.adventist.org. What helped was when I disabled the HTTP and compression filter. Then I read that the "fix" will solve my problem. So I installed SP2 and the fix. What happened was that the client just gets a different error:
502 Proxy Error. The request was rejected by the HTTP filter. Contact your ISA Server administrator. (12217).
However, in ISA, I still get the same eror in my logs, saying something like "utf-8 compression is not supported." I have not put any header or signature blocks in the HTTP properties of the rule or in the "configure HTTP" menu.
I can just disable the HTTP filter again, but my boss is breathing down my neck to block the download of certain types of files...like videos, streaming, music files, etc.
Is there perhaps another way of doing it apart from using the HTTP filter? or can someone try to identify my problem and provide a solution? I would really appreciate it.
Thanks.
RE: UTF-8 compression - 18.May2006 1:47:46 AM
Ooops! misread your post...
Jason Jones (MVP)
(in reply to ThatOtherGuy)
RE: UTF-8 compression - 19.May2006 1:37:06 PM
ThatOtherGuy
Is the question unclear?
