Unable to load java applet
All Forums >> [ISA 2006 General] >> General >> Unable to load java applet Page: [1]
Unable to load java applet - 17.Nov.2006 7:40:08 AM
awaismajeed
Dear All,
I have been facing a problem from quite long and it has just made mee crazy. problem is that i am unable to load a java applet form one of the website. i have done alomost all exercises and hit an trial but all result in nothing just the following error which pops up on java consol.
kindly help me in this regard. moreover there is nothing worn with the url acessing as while i try is on standalone machine it works fine but as i open it in LAN ISA server 2000 environment is ends up with the following message as applet is unable to load.
meanwhile the website  opens fine  on server where i have deployed ISA server.
Java Plug-in 1.5.0_09
Using JRE version 1.5.0_09 Java HotSpot(TM) Client VM
User home directory = D:\Documents and Settings\Abrar Chaudhury
c:   clear console window
f:   finalize objects on finalization queue
g:   garbage collect
h:   display this help message
l:   dump classloader list
m:   print memory usage
o:   trigger logging
p:   reload proxy configuration
q:   hide console
r:   reload policy configuration
s:   dump system and deployment properties
t:   dump thread list
v:   dump thread stack
x:   clear classloader cache
0-5: set trace level to <n>
 i m in the Exception of btnDisconn
 i m after Destroy
in ConnectHost 202.147.190.20 Port
java.security.AccessControlException: access denied (java.net.SocketPermission 202.147.190.20:4040 connect,resolve)
    at java.security.AccessControlContext.checkPermission(Unknown Source)
    at java.security.AccessController.checkPermission(Unknown Source)
    at java.lang.SecurityManager.checkPermission(Unknown Source)
    at java.lang.SecurityManager.checkConnect(Unknown Source)
    at java.net.Socket.connect(Unknown Source)
    at java.net.Socket.<init>(Unknown Source)
    at atsstat.ATSSTAT.drawImage(atsstat/ATSSTAT)
    at atsstat.ATSSTAT.init(atsstat/ATSSTAT)
    at sun.applet.AppletPanel.run(Unknown Source)
    at java.lang.Thread.run(Unknown Source)
java.security.AccessControlException: access denied (java.net.SocketPermission 202.147.190.20:2323 connect,resolve)
    at akdtop25.RateGridApplet.abs(akdtop25/RateGridApplet)
    at akdtop25.RateGridApplet.init(akdtop25/RateGridApplet)
RE: Unable to load java applet - 17.Nov.2006 11:50:44 AM
The application might not be compatible with Web proxies.
(in reply to awaismajeed)
