Unexpected web proxy behaviour
Unexpected web proxy behaviour - 27.Nov.2003 5:35:00 PM
ptwilliams
Hello,
A user just encountered this isssue. When I type serverName.domainName.com into my web browser ISA asks for authentication. For example, server1.my-domain.com
( HTTP 407 Proxy Authentication Required - The ISA Server requires authorization to fulfill the request. Access to the Web Proxy service is denied. (12209) )
ISA is setup with the following entries in it's LDT: *.my-domain.com *.my-domain.com.
My IE proxy settings are also set to "Bypass Proxy Server for Local Address".
Why is this behaviour happening?
Thanks, in advance
Paul.
RE: Unexpected web proxy behaviour - 28.Nov.2003 1:11:00 PM
ptwilliams
Where is everybody?
Thanksgiving holidays (for the US guys)?
RE: Unexpected web proxy behaviour - 5.Dec.2003 1:20:00 PM
ptwilliams
Anyone?
I've done this: http://support.microsoft.com/default.aspx?scid=816959
Somebody mentioned the fact that I'm a SNAT client. However, I thought that adding the domain suffix to the LDT was how to deal with such an issue?
RE: Unexpected web proxy behaviour - 5.Dec.2003 1:56:00 PM
AlexS
Hello Paul.
Strange that nobody ansered you; however the problem seem to be very simple; it all depends on how you configured your ISA server.
SNAT is not the cause: you get 407 error in your browser = means that your browser successfully contacted web proxy service.
Please note that ISA LDT entries and IE "Bypass Proxy Server for Local Address" are completely independent things. The latter option in IE instructs it to contact web site directly if hostname is plain (no dots in name) or you entered host/domain to the Intranet zone in IE.
ISA LDT is for Firewall clients ONLY; it controls how name resolution is performed. Web Proxy and SNAT client do not (and cannot) use ISA LDT. Check ISA help about this.
The problem that you have may be caused by mentioned by you article
or something similar.
If you want more help, please specify how you configured Outbound Web Proxy Listener, including authentication types, and what are are your Protocol and Site+Content rules.
HTH, Alex
RE: Unexpected web proxy behaviour - 5.Dec.2003 6:26:00 PM
AlexS
Well, Digest authentication requires some prerequisites, like listed in the following article:
http://support.microsoft.com/default.aspx?scid=kb;EN-US;222028
You may try to:
1. Disable digest authentication, leavin only Integrated. 2. Make sure that "Enable Intergrated Authentication" option is checked in IE Advanced options.
Alex
RE: Unexpected web proxy behaviour - 9.Dec.2003 5:21:00 PM
ptwilliams
Alex,
I removed digest authentication and tried again with and without enable integrated... in IE. Both failed. Modifying the domain-name.com to *.domain-name.com in the advanced section of IE's proxy settings has resolved this issue.
What I don't understand is why, when *.domain-name.com isn't present, I can't get to the site. Even if the proxy service thinks it's an external address, the machines and user have unlimited www access. The only thing I can think of is that it is trying to access the internal (intranet) site from the dirty side of the firewall. Do you think this could be the case?
I'm probably way off the mark here, but this seems like a rather fundamental issue to be having???
Paul.
RE: Unexpected web proxy behaviour - 17.Dec.2003 12:53:00 AM
cabaldochoa
On Tools->Internet Option->Connections->LAN settings->Proxy Server->Advanced->Exceptions, write *.your-domain.com;*.your-domain.com;etc.. then OK
RE: Unexpected web proxy behaviour - 17.Dec.2003 11:43:00 AM
ptwilliams
Thanks cabaldochoa,
What I'm now after is the reason why http://serverName.domain-name.com will only work when *.domain-name.com is an IE exception, whereas http://serverName works fine.
Why does ISA block FQDN's of internal resources? I'm unaware of my rules blocking this?
Paul.
RE: Unexpected web proxy behaviour - 17.Dec.2003 1:12:00 PM
AlexS
That's simple.
http://serverName URL is always considered by IE as "Local Intranet" zone site.
Any dotted names (serverName.domainName) AND IP addresses are always considered by IE as non-intranet zone, unless you manually add the URL to the zone.
If you have "bypass proxy for interanet" IE option enabled, then intranet hosts will be contacted directly, all other hosts - using web proxy service.
To resolve your original problem, you should add *.domainName.com to Intranet Zone (or bypass proxy) settings in IE; if you don't, you can try other ways, like:
http://support.microsoft.com/default.aspx?scid=kb;en-us;322822 http://support.microsoft.com/default.aspx?scid=kb;en-us;299838
HTH, Alex
RE: Unexpected web proxy behaviour - 17.Dec.2003 2:29:00 PM
Hey guys,
Make sure you configure the clients to use the auto config script so that they use the LDT for direct access and then confirm that you're split DNS is in place.
There a good article on Direct Access in the SharePoint Portal Server Deployment Kit doc.
HTH, Tom
RE: Unexpected web proxy behaviour - 2.Feb.2004 2:57:00 PM
ptwilliams
I'll give this topic a little boost in the hope somebody can help with the last question posted.
Paul.
RE: Unexpected web proxy behaviour - 5.Feb.2004 1:55:00 PM
ptwilliams
Anyone? Tom?
RE: Unexpected web proxy behaviour - 9.Feb.2004 10:10:00 PM
ptwilliams
...Make sure you configure the clients to use the auto config script so that they use the LDT for direct access and then confirm that you're split DNS is in place...
This is the part I'm still querying...
Paul.
