Upgrade Problem
Upgrade Problem - 23.Jul.2004 10:12:00 PM
jpierini
Hi there, I've been working with the Beta 2 release a lot of time. Then, when the final version cames, I was ready to upgrade. 1- I ca not upgrade the product, so I backed up ALL MY POLICIES, uninstall the Beta version, and install the final.
2- When I tried to restore my saved policies, I got an "Version Error" that frooze me. It said that my XML object version is older than current. YES, IT IS !
Please ISA Master, help me with this issue. I don't want to write all policies/configurations again !
Thnks,
Javier
RE: Upgrade Problem - 16.Aug.2004 11:10:00 AM
Well, there is a way. If you export your rules to an XML-file, you can import them back in the release if you edit the header in the XML file (build number and namespaces) I have tested it, and it works. Had to fix some minor things, but it saved me several hours of work.
