Url blocking - not consistant?
All Forums >> [ISA Server 2004 Firewall] >> HTTP Filtering >> Url blocking - not consistant? Page: [1]
Url blocking - not consistant? - 14.Jun.2004 8:09:00 PM
NetworkNewbie
I'm trying to setup ISA Server 2004 on a small test network and I can't seem to get ISA to block specific websites - or at least not all of them. I can get it to block www.aol.com, www.yahoo.com, and www.slashdot.com. However, for some reason www.collegehumor.com will not properly block. For all of these sites, the entry in the URL Set in ISA is "*.<domain>.com". Does anyone have any idea why this particular website (and others I would assume) would not be caught by the URL Set filter? Thanks for the help!
RE: Url blocking - not consistant? - 15.Jun.2004 5:45:00 PM
Hi Newbie,
Check which rule is allowing the request. Often, a rule higher up on the list is allowing a connection that you think is blocked by a deny rule.
(in reply to NetworkNewbie)
RE: Url blocking - not consistant? - 16.Jun.2004 8:21:00 PM
NetworkNewbie
It is the #1 rule in the firewall policy. Furthermore it was only www.collegehumor.com that we could not block, but by putting in collegehumor's IP address we successfully blocked the site even though the web page on MS site says this can't be done. Do you know why this behavior is happening?
RE: Url blocking - not consistant? - 18.Jun.2004 1:19:00 AM
Hi Newbie,
In the real time log viewer, what URLs are actually being accessed? What are the details of your URL set? I'll check this out myself on my own ISA 2004 firewall and see what happens.
RE: Url blocking - not consistant? - 6.Jul.2004 8:08:00 PM
NetworkNewbie
Our URL set that we are testing with consists of:
*.aol.com
*.collegehumor.com
*.playboy.com
*.yahoo.com
http://collegehumor.com
http://slashdot.org
All sites block properly except for collegehumor. The event log for successful blocks reads:
Destination host: 0.0.0.0
Port: 80
Protocol: http (yes, in lowercase)
Action Taken: (none given)
Client username: anonymous
Source network: Local Host
Destination network: External
HTTP Method: GET
URL: http://209.247.228.201/ (this one is www.playboy.com)
For www.collegehumor.com though, we get:
Destination host: 63.208.177.10
Port: 80
Protocol: HTTP
Action: Denied Connection
Client username: (none given)
HTTP Method: (none given)
URL: (none given)
Thanks again for the help.
RE: Url blocking - not consistant? - 6.Jul.2004 10:48:00 PM
Hi Newb,
Let me test it and I'll be right back.
RE: Url blocking - not consistant? - 6.Jul.2004 11:01:00 PM
Hi Newb,
I've tested it on SecureNAT, Firewall and Web Proxy client configs, all separately.
Created a Domain Set and entered into the domain set:
collegehumor.com
Create an Access Rule that Denied all protocols from Source Internal to Destination Domain Set Collegehumor.com.
Blocked the connection for all three ISA client types.
Give it a try!
RE: Url blocking - not consistant? - 8.Jul.2004 6:39:00 AM
leslie
Works just fine. Can we add a deny page to this blocked url set? I just get the pop up asking for the password?
RE: Url blocking - not consistant? - 8.Jul.2004 2:14:00 PM
Hi Leslie,
Are you using the Firewall and Web Proxy client? If so, you should not see any authentication log on dialog box.
