Use logging filters on Enterprise Access Rules
All Forums >> [ISA Server 2004 Misc.] >> ISA Server 2004 Wish List >> Use logging filters on Enterprise Access Rules Page: [1]
Use logging filters on Enterprise Access Rules - 20.Nov.2005 3:32:21 PM
wbplomp
You are now unable to use logging filters with Enterprise Access Rules. Check it out, they should fix that.
RE: Use logging filters on Enterprise Access Rules - 20.Nov.2005 4:58:48 PM
Hi W,
Not sure what you mean. Are you saying that you can't disable logging for certain rules?
(in reply to wbplomp)
RE: Use logging filters on Enterprise Access Rules - 20.Nov.2005 5:05:29 PM
wbplomp
No, when you are checking live logging, you can choose some filter. One of these filter like:
Rule - Equals - <your_manual_created_access_rule>
But you can only select Access Rules you created at the Array level, rules you created at the Enterprise are not visible.
Gr. Boudewijn
RE: Use logging filters on Enterprise Access Rules - 20.Nov.2005 5:08:58 PM
wbplomp
I also noticed some other issues.
When you select "MIME Type" as a filter within the live logging, the list is empty when you use ISA Server 2004 EE. When you use ISA Server 2004 SE the list shows al Content Types that are available. I checked if it had to do with my installation. But I noticed this was the case on three ISA Server EE installations. I think it is a bug.
Gr. Boudewijn
< Message edited by wbplomp -- 20.Nov.2005 5:11:48 PM >
