Users prompted for password in IE
All Forums >> [ISA Server 2004 Firewall] >> General >> Users prompted for password in IE Page: [1]
Users prompted for password in IE - 1.Nov.2005 3:09:00 PM
tprzybylak
Odd issue.
I am running ISA 2004 and certain random users are prompted to enter a password when they open their web browser - while others (about 90%) can open IE and go right through without authenticating to the ISA server. They are all in the same domain, logging into the same domain as ISA, etc. It has me baffled as I cannot find any reason why these certain users who seem to have no common trait are getting prompted. Sometimes they have to authenticate for every web page, and it has gotten to be annoying.
Thoughts?
RE: Users prompted for password in IE - 1.Nov.2005 3:14:00 PM
is the 'Require all users to authenticate Web Proxy setting' configured for the Internal interface of your ISA 2004 server? If so, make sure you have implemented http://support.microsoft.com/default.aspx?scid=kb;en-us;885683 .
(in reply to tprzybylak)
RE: Users prompted for password in IE - 1.Nov.2005 3:16:00 PM
tprzybylak
Where do I find that setting? I was looking for it and can't track it down!
RE: Users prompted for password in IE - 1.Nov.2005 3:25:00 PM
Configuration -> Networks -> Internal -> Properties -> Web Proxy -> Authentication.
BTW --- if you don't need it checked for a specific reason, leave it unchecked.
RE: Users prompted for password in IE - 1.Nov.2005 3:26:00 PM
tprzybylak
I believe i had it checked to make sure that I had user names instead of IP addresses in the logs. Is this correct? Or am I off base?
Thank you for your prompt replies!
RE: Users prompted for password in IE - 1.Nov.2005 3:33:00 PM
it's not needed for that. Instead you should require authentication on a rule base. For more info, check out http://www.isaserver.org/articles/ISA2004_AccessRules.html .
RE: Users prompted for password in IE - 1.Nov.2005 3:42:00 PM
tprzybylak
Stefan:
Worked like a champ. Thank you so much for your help - Much appreciated.
Case Closed!@
RE: Users prompted for password in IE - 1.Nov.2005 3:45:00 PM
good to hear you have it working and thanks for the follow up! [Smile]
