Using Alt Ports for SSL
All Forums >> [ISA Server 2004 Misc.] >> Tips and Tricks >> Using Alt Ports for SSL Page: [1]
Using Alt Ports for SSL - 10.Feb.2005 6:50:00 PM
PureKaine
Recently I was having a problem connecting to a web page that used an alternate port for SSL communication. No matter what I did in ISA, I could not connect to this site. While searching MSKB I found this vbs script to add
Copy this script to a txt file and then rename to .vbs to work.
Dim root
Dim tpRanges
Dim newRange
Set root = CreateObject("FPC.Root")
Set tpRanges = root.GetContainingArray.ArrayPolicy.WebProxy.TunnelPortRanges
set newRange = tpRanges.AddRange("SSL 9443", 9443, 9443)
tpRanges.Save
In bold are the Start and End ports that will need to be modified to fit your scenario.
If script runs successfully there will be no message, if you run the same script a second time you will get an error stating something to the effect of "cannot create, already exists".
Hope this helps.
RE: Using Alt Ports for SSL - 10.Feb.2005 7:30:00 PM
Hi Kaine,
Great tip!
(in reply to PureKaine)
RE: Using Alt Ports for SSL - 12.Oct.2005 2:47:00 AM
chrigi-ch
Hi
there is a tool from the website http://www.isatools.org, it is called
isa_tpr.js which adds extra https ports to the
ISA server.
Greets
Chrigi-CH
RE: Using Alt Ports for SSL - 13.Oct.2005 4:31:00 PM
And a script named "Manage_SSL_Ports.vbs" at www.ISAscripts.org that can show, add or delete allowed SSL port ranges in a user-friendly way, plus a bunch of other scripts.
