Using Credtool and wspcfg.ini to allow McAfeeInstantUpdater/1.0 through ISA
All Forums >> [ISA Server 2000 Firewall] >> Firewall Client >> Using Credtool and wspcfg.ini to allow McAfeeInstantUpdater/1.0 through ISA Page: [1]
Using Credtool and wspcfg.ini to allow McAfeeInstantUpd... - 14.Nov.2003 3:38:00 AM
Kurt James
Here goes:
I am trying to get the update program for Viruscan Professional Edition 7.02.6000.
The update engine is called RuLaunch.exe.
So far, I post a question about it on the forums and someone recommended using credtool.
I have done the following:
Created a new user in the active dir called: virususer
Virususer has been given full permissions to access the internet.
Then on the PC that has the virusscan software, I have created a file called wspcfg.ini.
Contents of wspcfg.ini are as follows:
[RuLaunch.exe]
ServerBindTcpPorts=80
LocalBindTcpPorts=80
RemoteBindTcpPorts=80
KillOldSession=1
ForceCredentials=1
I have placed (as instructed) the wspcfg.ini file into the applications folder:
C:\Program Files\McAfee\McAfee Shared Components\Instant Updater
Now using credtool on the pc I did the following:
credtool -w -n RuLaunch -c virususer domainnamehere passwordhere
Then rebooted.
I ran the updater and nothing..zip!
I checked the logs and the updater did not have the credentials as made using credtool.exe.
The update engine is shown as anonymous and the application is shown as McAfeeInstantUpdater/1.0
* Could it be that the wspcfg.ini should specify this name instead?
The request made by anonymous was:
GET
http://download.mcafee.com/products/licensed/central/english/patches/CTL251AU.ini
The result was:
- 12209
This is becoming a complicated process...does anyone have an understanding of how to get applications through as authenticate individual users???
Many thanks in advanced and if you managed to read all this.
Kurt
RE: Using Credtool and wspcfg.ini to allow McAfeeInstan... - 14.Nov.2003 5:12:00 AM
>>GET
This is HTTP request!
First, check FirewallLog to find out is APPLICATION makes authorisation. Look for record
like
10.0.0.11 User wins.exe:3:5.0 Y 14.11.2003 01:01:19 fwsrv ST2 - - 194.xxx.xxx.xx 42 10 109 93 42 TCP Connect - - - 20000 0 pr WINS scr WINS replication 115 2405
If found, than make follow.
Second, read the tutorial about HTTP redirection filter "Mystery" on that site.
(in reply to Kurt James)
RE: Using Credtool and wspcfg.ini to allow McAfeeInstan... - 15.Nov.2003 8:48:00 AM
iahsan
Make a destination set with the following and allow direct access to it. This is in case you are blocking application/octet-stream
download.mcafee.com
bin.mcafee.com
Your HTTP redirector should be set to send all HTTP traffic to Web Proxy.
Imran
[ November 15, 2003, 08:49 AM: Message edited by: I m r a n ]
