Using RADIUS authentication in Access Rules
All Forums >> [ISA Server 2004 Firewall] >> Access Policies >> Using RADIUS authentication in Access Rules Page: [1]
Using RADIUS authentication in Access Rules - 10.Feb.2005 6:03:00 PM
massimo_m
Hi everyone
I was wondering about using RADIUS auth instead of usual Windows auth to control Access Rules for my company.
My point is: In all ISA2004 documentation RADIUS is mentioned only to control VPN dial-in connections. If my ISA2004 is not member of an AD forest, I thought RADIUS can be used to authenticate outgoing web requests... but I'm trying to do it and I just can't figure out the process (Radius is specifically designed for Dial-in connections and no other kind of connections)..
Can you please confirm me that RADIUS auth can ONLY be used by ISA2004 for VPN connections?
RE: Using RADIUS authentication in Access Rules - 10.Feb.2005 9:29:00 PM
Hi Massimo,
Yes, you can use RADIUS auth for Web Proxy auth. We have that in the book.
(in reply to massimo_m)
RE: Using RADIUS authentication in Access Rules - 11.Feb.2005 4:10:00 PM
massimo_m
Thanks Tom but I just needed a tip not a new book ;-)
I think I've found the method to use Radius for WebProxy Auth.. The only things I can't find are:
1) When configuring access rules, in "Users" TAB, I select ADD/NEW, I see "New User Wizard", I click ADD/Radius/Specified User Name/ and I type MYDOMAIN\myuseraccount
is it right?
2) In my IAS Server, I think there is no futher configuration other than the simple creation of RADIUS Client. No Realms configuration is needed, isnt it?
RE: Using RADIUS authentication in Access Rules - 27.Feb.2005 10:00:00 PM
Do you have to fill inn the domainname if you use radius? in domain\userid
If so, even if all users a a member of the same domain?
PS: i have ordered the book from the local dealer tonight..:-)
RE: Using RADIUS authentication in Access Rules - 8.Mar.2005 11:57:00 AM
bump...no answer
