Using Response.Redirect from ASPX code
All Forums >> [ISA 2006 Misc.] >> ISA 2006 Programming >> Using Response.Redirect from ASPX code Page: [1]
Using Response.Redirect from ASPX code - 20.Feb.2007 10:50:06 PM
hjadkins
I'm trying to do a simple test to see if a aspx page is secure, if not redirect back to itself inserting https.  The code I'm using is below:
It seems to get caught in circlular reference, becuase the IsSecureConnection after the redirect still reads false, but if you go to the page manually by typing in the URL, the IsSecureConnection reads true.  The  Response.Redirect should respond the same just as if you were tryping it in, but ISA is handling it different.
be aware if you test the code, hit the stop button right away or you'll flood your IIS server with the same page request.
Thanks for any insight or thoughts on the issue:
.Net 2.0, ISA Server 2006 Ent.
If
Not Page.IsPostBack Then
  If Request().IsSecureConnection = False Then
     Response.Redirect("https://" & Request.ServerVariables("HTTP_HOST")  & Request.ServerVariables("PATH_INFO"), True)
  End If
 Label1.Text = Request().IsSecureConnection.ToString
End If
RE: Using Response.Redirect from ASPX code - 23.Feb.2007 11:18:26 PM
hjadkins
Update on the issue:
What is Microsoft thinking .... what a oversight in functionality.
http://www.eggheadcafe.com/software/aspnet/29098662/re-redirect-http-to-http.aspx
http://support.microsoft.com/kb/924373
Microsoft: Fix the problem, this is a bug, 302 redirect should be allowed, you broke allot of code aspx code.
(in reply to hjadkins)
