Using a router in front of ISA for PPPoE
All Forums >> [ISA Server 2004 Firewall] >> General >> Using a router in front of ISA for PPPoE Page: [1]
Using a router in front of ISA for PPPoE - 12.Jul.2005 3:22:00 PM
kegan
I have heard that this is the best way to avoid issues relating to DHCP/MTU and other stability and reliability issues with PPPoE DSL connections.
My plan is to put a SOHO router in front of ISA 2004 (running on SBS 2003). Here's the configuration as I envision it:
Internal IP for SBS NIC: 192.168.16.2/24
External IP for SBS WAN NIC: 10.0.0.2/24
SOHO Router LAN IP: 10.0.0.10/24
SOHO Router WAN (PPPoE static) IP: 64.26.175.52
I assume the ISA server will be performing NAT to the 10.0.0.x network. The SOHO router by default will perform NAT again to the Internet. Correct? Are there issues with this and is this the correct configuration?
2. Am I correct that to host services on my internal network, I will need to configure rules on ISA and port forwarding to 10.0.0.2 on the SOHO router?
3. We will use OWA, RWW, RPC over HTTP, and VPN. Will this configuration even work for services like VPN? If not, what changes need ot be made?
Your clarification and guidance is appreciated.
Kevin
RE: Using a router in front of ISA for PPPoE - 12.Jul.2005 10:54:00 PM
Hi Kevin,
1. I assume the ISA server will be performing NAT to the 10.0.0.x network. The SOHO router by default will perform NAT again to the Internet. Correct? Are there issues with this and is this the correct configuration?
TOM: There are no issues. If you find speed is a bit slower than you expected, try enabling PMTU discovery on the ISA firewall.
TOM: Yes, works great, including VPN PPTP and L2TP/IPSec!
TOM: I don't know anything about RWW, but all the other services work fine.
(in reply to kegan)
