VO-IP problems H.323 protocol
All Forums >> [ISA Server 2004 General ] >> Server Publishing >> VO-IP problems H.323 protocol Page: [1]
VO-IP problems H.323 protocol - 16.Sep.2004 8:25:00 PM
iphase
Hi
I am publishing a VO-IP gateway through my ISA 2004 Server.
Currently everthing is fine "sort of"
I can get the calls through but they arent bidirectional, so only one side can talk.
But this is only when I disable the IP filtering rules.
when they are turned on by default, the following error appears on my server log.
Result Code
0xc0040017 FWX_E_TCP_NOT_SYN_PACKET_DROPPED
on port 1720 when using the h.323 protocol.
when disabled. everything is fine. except for the one way call thing.
So now i notice the folliwing in my logs.
Destination IP
xxxxx
Destination Port
1720
Source Port
20006
Protocol
H.323 Protocol
Source Network
Internal
Destination Network
External
Bidirectional
No
Transport
TCP
How come it is'nt bi-directional??
Any answer leading to the resolution to my problem is greatly appreciated. i've been working on this problem for over a week now!
[ September 16, 2004, 08:26 PM: Message edited by: IPhase ]
RE: VO-IP problems H.323 protocol - 17.Sep.2004 5:14:00 AM
Hi Micheal,
How did you publish the H.323 protocol? As far I as remember, there isn't an H.323 Server protocol definition.
(in reply to iphase)
RE: VO-IP problems H.323 protocol - 17.Sep.2004 11:21:00 AM
iphase
Here is the protocol I made and published.
from external to the internal IP using the normal server publishing wizard .view.
I added the h.323 access filter.
RE: VO-IP problems H.323 protocol - 20.Sep.2004 8:58:00 PM
iphase
Hi Tom
Have you got anything to add? or are you as confused by this protocol as I am?
