VOIP SIP Successful
All Forums >> [ISA Server 2004 Firewall] >> General >> VOIP SIP Successful Page: [1]
VOIP SIP Successful - 7.Nov.2005 1:15:00 AM
david803sc@msn.com
Wanted to let evryone know I have AT&T Call Vantage VOIP service using SIP on a Centillium router, I hooked the WAN port of the router to my LAN after giving it the appropriate LAN static IP, it worked no problem, incoming and outgoing calls no problems, I didn't even set any special access rules or publish any ports.
David
RE: VOIP SIP Successful - 7.Nov.2005 4:42:00 AM
Hi David,
That's good to hear.
What is the configuratino of the Access Rule that is allowing the connection(s)?
(in reply to david803sc@msn.com)
RE: VOIP SIP Successful - 7.Nov.2005 9:32:00 AM
david803sc@msn.com
I have an Internet Access Rule to allow all outbound traffic and protocols. When I first tried it it worked however to be on the safe side I added the following outbound protocols, that AT&T Call Vantage recomends:
5060-5061 UDP Send / Recieve
RTP 10000-10015 UDP UDP Send / Recieve
I have no publishing rules set, no TFTP, and my NTP was already set in the FIrewall Policy to allow all.
David
