VPN/Stub Network design issue
VPN/Stub Network design issue - 7.Oct.2004 5:23:00 PM
Saltin
Hello all...
My network design is summed up in the article found (there's a diagram that describes it prefectly) Here
The stub subnet is 192.168.4.0/24 Four other internal subnets are reachable through my layer 3 device (Cisco 2611XM). Routing is working, no issues.
My problem is stemming from assigning VPN clients IP addresses. I would like to assign IP's from a static pool. Obviously, these IP's ,must fall in the 192.168.4.0/24 range, as this is the subnet the are connecting to. After that, the Cisco router allows them to reach other subnets in the internal network. Unfortunately, because I have 192.168.4.0/24 defined (among all other internal subnets) in my Internal Network object, I cannot build a static pool for VPN clients of 192.168.4.0/24 ! The VPN network object and internal network object would then have overlapping address ranges, which isnt allowed.
Obviously I don't understand this reasoning! How can I assign my VPN clients any address other than from range 192.168.4.0/24 ? Impossible. How can I not define 192.168.4.0/24 as part of my internal network?
Thanks! [ October 07, 2004, 05:24 PM: Message edited by: Saltin ]
RE: VPN/Stub Network design issue - 7.Oct.2004 6:04:00 PM
AbqBill
Hi Saltin,
The answer is that ISA Server 2004 considers the VPN clients to be a separate network object to which rules can be applied. As you have found, network IP ranges can't overlap.
To work around your issue, simply exclude the static pool of VPN IP addresses from the IP ranges found in your Internal Network object.
Bill
RE: VPN/Stub Network design issue - 7.Oct.2004 6:48:00 PM
Saltin
Geeze.
Looking at that answer it seems so obvious! Thank you very much.
I guess I was working under the assumption that I could only include full subnet ranges in the internal network component.
Clearly that is a poor assumption!
RE: VPN/Stub Network design issue - 7.Oct.2004 7:07:00 PM
AbqBill
Hi Saltin,
Glad to have helped.
Bill
RE: VPN/Stub Network design issue - 7.Oct.2004 7:35:00 PM
Hey guys,
Just for the future, if you use DHCP for assigning the VPN clients addresses, you can have the VPN clients network use an overlapping range.
Its just a "peculiarity" of how ISA and VPN client addressing works.
HTH, Tom
RE: VPN/Stub Network design issue - 8.Oct.2004 4:59:00 PM
AbqBill
That's true -- since RRAS requests a block of 10 addresses at a time (by default) from the DHCP server, ISA Server "knows" that these addresses will be part of the VPN Clients network as soon as they are in use by remote VPN clients.
Bill
