VPN-Q Deployment guide - rqc.exe parameters
VPN-Q Deployment guide - rqc.exe parameters - 22.Jun.2007 12:54:28 PM
johnny_mango
Hi there, I have been battling for 3 days with a very simple implementation of the ISA Server quarantine. Everything seems to be working well, PPTP, L2TP, the only problem being the CMAK profile, the system variables and the script, or a combination thereof. Bascially I have been following closely the VPN Deployment Guide, from Microsoft, using the sample script there which checks for the presence of a text file and then copies it onto the connecting computer from a server. I have all the access rules etc set up as they should be. The problem is the rqc.exe component on the client, and the parameters it is passing to the server component, rqs.exe. It seems that it is not passing a parameter, or isn´t passing the correct one, presumably due to some mistake I´ve made when creating the CMAK profile. Every resource on the Internet, although there are not many, has a different example script, a different set of environment profiles that the CMAK profile passes and none of them work, believe me, I´ve tried them all. Does anyone have any kind of working script, and the details of the CMAK profile they created? It seems like an excellent tool, but I am poor with scripts etc., and am expecting to haver to implement it for AV and OS in a week or so. The information returned by the command line window is: Checking for c:\access.txt c:\access.txt found! Executing "C:\Documents and Settings\Administrator\Application Data\Microsoft\Ne twork\Connections\Cm\vpnnew"\rqc.exe NULL "vpn deploy new" 7250 completelab pstuser2 Key Press any key to continue . . . In the rqc log file in Windows\Tracing I see: [704] 12:21:16: Info: Usage: rqc.exe /conn ServiceProfileName [/domain DomainName] [/user UserName] [/port PortNumber] [/sig Signature] [/log LogFileName] [/?] [704] 12:21:16: Info: /conn Required. Specifies the name of the service profile for which you want to run RQC. [704] 12:21:16: Info: /domain Specifies the domain name. [704] 12:21:16: Info: /user Specifies the user name. [704] 12:21:16: Info: /port Specifies the port number used by RQC to connect to quarantine server. [704] 12:21:16: Info: /sig Specifies the signature that sent to quarantine server to validate the client. [704] 12:21:16: Info: /log Specifies the log message sent to the quarantine server. Not much help really!! Thanks a lot.
