VPN Authentication Problem
All Forums >> [ISA 2006 Firewall] >> VPN >> VPN Authentication Problem Page: [1]
VPN Authentication Problem - 23.Jul.2008 1:50:21 PM
itsallwright
I have 2 NLB ISA 2006 Ent servers in an array running Windows Server 2003 R2 SP2 and joined to the domain.  When I try to VPN in, authentication takes a really long time if it works at all (sometimes it times out).
VPN configuration:
- VPN is enabled
- Assigned a domain group with vpn users as members.
- Both PPTP and L2TP are selected for Protocols.
- User Mapping is unchecked.
- External network selected under access networks.
- Address Assignment is set to Static Pool.
- Authentication is set as MS-CHAPv2.
- No RADIUS selected.
In the System log on the ISA server that handled the request, I see several of the following events.
Event Type: Warning
Event Source: RemoteAccess
Event Category: None
Event ID: 20189
Date:  7/23/2008
Time:  12:33:57 PM
User:  N/A
Computer: ISAServer
Description:
The user <Domain>\<UserName> connected from x.x.x.x but failed an authentication attempt due to the following reason: Authentication was not successful because an unknown user name or incorrect password was used.
In the Security log of the Domain Controller (Server 2008 x64), I see several of these events.
Log Name:      Security
Source:        Microsoft-Windows-Security-Auditing
Date:          7/23/2008 12:34:12 PM
Event ID:      4776
Task Category: Credential Validation
Level:         Information
Keywords:      Audit Failure
User:          N/A
Computer:      DC.mydomain.com
Description:
The domain controller attempted to validate the credentials for an account.
Authentication Package: MICROSOFT_AUTHENTICATION_PACKAGE_V1_0
Logon Account: <UserName>
Source Workstation:
Error Code: 0xc000006a
I researched the error code listed above and it means:
0xC000006A - The value provided as the current password is not correct
The previous events are followed by the following single event upon success (if it doesn't time out).
Log Name:      Security
Event ID:      4776
Level:         Information
Keywords:      Audit Success
User:          N/A
Description:
Source Workstation:
Error Code: 0x0
If I use a local account on the ISA server, it works almost instantly as expected.
Any suggestions to a solution would be greatly appreciated.
Jay
RE: VPN Authentication Problem - 24.Jul.2008 7:49:59 PM
itsallwright
OK, more info... I just discovered that VPN authentication works instantly as expected when I go to the primary external IP of either ISA server.  It only shows these symptoms when I go to the load balanced IP.
I tried disabling network load balancing integration and it still worked to the external IP (obviously not to the NLB IP) on both servers.  I then enabled NLB again and still have the same symptom I started with.
Any idea what might be wrong with NLB?
Jay
(in reply to itsallwright)
RE: VPN Authentication Problem - 8.Aug.2008 9:56:39 AM
itsallwright
Does anyone have any suggestions to help me figure this out?  I am at a loss.  The only thing I can think to do now is to rebuild both ISA servers in the array.  I really don't want to do this.
Let me know if I can provide any more details to help troubleshoot this problem.
Thank you,
Jay
