VPN Connection Problem (Screenshots Included)
All Forums >> [ISA 2006 Firewall] >> VPN >> VPN Connection Problem (Screenshots Included) Page: [1]
VPN Connection Problem (Screenshots Included) - 25.May2008 9:26:58 PM
flysurfing
Dear all,
My ISA 2006 Enterprise VPN  doesnt work anymore. When we try to connect to the VPN as before we have no answer.
Could you help me to check some points who are maybe causing this problem ?
Please find some screenshots of our system configuration:
http://img148.imageshack.us/img148/6330/vpnpropertiesaccessnetwlx0.jpg
http://img514.imageshack.us/img514/5733/vpnpropertiesauthenticaqx3.jpg
http://img102.imageshack.us/img102/4176/vpnpropertiesusermappinkv3.jpg
http://img148.imageshack.us/img148/8876/vpnpropertiesgroupsae4.jpg
http://img514.imageshack.us/img514/6064/vpnpropertiesgeneraldu4.jpg
http://img102.imageshack.us/img102/8762/vpnpropertiesradiuot5.jpg
http://img514.imageshack.us/img514/7530/vpnpropertiesprotocolsms7.jpg
http://img514.imageshack.us/img514/3317/vpnpropertiesaddressassur8.jpg
http://img505.imageshack.us/img505/5306/vpnpropertiesusermappinco9.jpg
If someone accept, i could give you an ip address and login to try the connect to our server.
Thanks a lot for your support !
Fly
< Message edited by flysurfing -- 13.Jun.2008 5:25:14 AM >
RE: Vpn doesnt work anymore. - 26.May2008 4:39:25 AM
Have you installed Windows Server 2003 SP2 ?
(in reply to flysurfing)
RE: Vpn doesnt work anymore. - 1.Jun.2008 11:49:05 PM
flysurfing
Dear elmajdal,
No we have only the SP1 installed.
Any idea ?
Pierre
(in reply to elmajdal)
RE: Vpn doesnt work anymore. - 13.Jun.2008 5:17:47 AM
flysurfing
I added some screenshots of our system.
Thanks to have a glimpse on it ;)
Cheers,
Fly
RE: Vpn doesnt work anymore. - 15.Jun.2008 3:58:34 AM
mmm,
What error message does your vpn users recieve ?
If you are using DHCP, have you configured the DHCP Relay agent ?
RE: Vpn doesnt work anymore. - 16.Jun.2008 2:46:18 AM
flysurfing
Hello Ejmedal,
No we are not using DHCP.
We are using address pool.
Shall we use DHCP relay agent.
Actually the error code when user connect is: error  800
Thanks.
FLY
RE: Vpn doesnt work anymore. - 16.Jun.2008 3:08:48 AM
HePa
According to this image > http://img514.imageshack.us/img514/3317/vpnpropertiesaddressassur8.jpg, you have configured your ISA server to use an internal DHCP server to lease ip-adresses to your clients. IF you don't have any DHCP relay agent installed on the ISA server the ISA server will not be able to relay the the requests to the DHCP server. Chech in RRAS if you have the DHCP relay agent installed.
HePa
RE: Vpn doesnt work anymore. - 16.Jun.2008 3:35:09 AM
ORIGINAL: flysurfing
Hello Ejmedal,
Thanks.
FLY
You do not have to use DHCP if you do not want, you can use static addressing for your VPN Client.
All what you have to do is to exclude this static range from the Internal Network Address Range.
what address pool ?? its either static or dhcp , and you have set it as dhcp , and you said that you do not use dhcp , then what ??
mmmm have you configured this address on RRAS ??? you should not, everything should be configured thru ISA Server Management Console
RE: Vpn doesnt work anymore. - 16.Jun.2008 3:58:04 AM
flysurfing
Hello Elmejdal,
We have re-configured the ISA server in Adress Assignment with this range of static adress pool: from 172.16.0.0 to 172.16.0.200.
Thanks for your help.
RE: Vpn doesnt work anymore. - 16.Jun.2008 4:02:44 AM
Hi Again,
and thing started to work ?
