VPN problem
All Forums >> [ISA Server 2004 Firewall] >> VPN >> VPN problem Page: [1]
VPN problem - 26.Jan.2008 9:02:44 AM
Nightlegend
Greetings:
I am trying to establis an VPN connection through ISA server 2004 standard edition ,I've set up all the necessary access rules and when trying to establish connection the dialog stops on the stage of (Verifying username and password) and nothing happens then the connecting process fails ,I am using the NIC public IP ,is this correct? or should I use the router's IP?
Thanks in advance
< Message edited by Nightlegend -- 27.Jan.2008 2:26:49 AM >
RE: VPN problem - 28.Jan.2008 6:50:23 AM
Have u followed this article : http://www.isaserver.org/articles/2004vpnserver.html
how is ur vpn client addressing set ? DHCP or static ?
how many NICs u have , and whats their IP/SM/DG/DNS ?
(in reply to Nightlegend)
RE: VPN problem - 6.Feb.2008 5:14:26 AM
Nightlegend
Dear Tarek:
I have tried earlier to email you ,but it got bounced back due to your spam filter!
Anyway I followed this tutorial first thing ,rechecked everything and all were followed accurately.
Checking the ISA server's log file I found the following:
Event Type:    Warning
Event Source:    Rasman
Event Category:    None
Event ID:    20209
Date:        1/30/2008
Time:        3:43:31 PM
User:        N/A
Computer:    MARINA-ISA
Description:
A connection between the VPN server and the VPN client 192.168.1.52 has been established, but the VPN connection cannot be completed. The most common cause for this is that a firewall or router between the VPN server and the VPN client is not configured to allow Generic Routing Encapsulation (GRE) packets (protocol 47). Verify that the firewalls and routers between your VPN server and the Internet allow GRE packets. Make sure the firewalls and routers on the user's network are also configured to allow GRE packets. If the problem persists, have the user contact the Internet service provider (ISP) to determine whether the ISP might be blocking GRE packets.
And this:
Event Type:    Warning
Event Source:    RemoteAccess
Event ID:    20169
Date:        1/30/2008
Time:        3:49:32 PM
User:        N/A
Description:
Unable to contact a DHCP server. The Automatic Private IP Address 169.254.132.79 will be assigned to dial-in clients. Clients may be unable to access resources on the network.
AND:
Event Type:    Warning
Event Source:    DnsApi
Event ID:    11163
Date:        1/30/2008
Time:        12:10:36 PM
User:        N/A
Description:
The system failed to register host (A) resource records (RRs) for network adapter
with settings:
  Adapter Name : {EF819C28-2A25-4988-8BB6-D36AF4666B97}
  Host Name : marina-isa
  Primary Domain Suffix : MARINA.DC
  DNS server list :
        192.168.1.6, 212.103.160.18
  Sent update to server : <?>
  IP Address(es) :
    192.168.1.4
The reason the system could not register these RRs was because the DNS server failed the update request. The most likely cause of this is that the authoritative DNS server required to process this update request has a lock in place on the zone, probably because a zone transfer is in progress.
You can manually retry DNS registration of the network adapter and its settings by typing "ipconfig /registerdns" at the command prompt. If problems still persist, contact your DNS server or network systems administrator.
Data:
0000: 2d 23 00 00               -#..
As for the addressing I am using static ranges 10.0.0.10 to 10.0.0.110 ,these ranges are not located within my network' default ranges (I am using 192.168.x.x) ,DHCP is disabled.
On the ISA server machine there are two NICs ,here's their information:
Microsoft Windows [Version 5.2.3790]
(C) Copyright 1985-2003 Microsoft Corp.
C:\Documents and Settings\isa admin>ipconfig /all
Windows IP Configuration
  Host Name . . . . . . . . . . . . : marina-isa
  Primary Dns Suffix  . . . . . . . : MARINA.DC
  Node Type . . . . . . . . . . . . : Unknown
  IP Routing Enabled. . . . . . . . : Yes
  WINS Proxy Enabled. . . . . . . . : Yes
  DNS Suffix Search List. . . . . . : MARINA.DC
Ethernet adapter Local Area Connection:
  Connection-specific DNS Suffix  . :
  Description . . . . . . . . . . . : HP NC373i Multifunction Gigabit Server Ad
apter
  Physical Address. . . . . . . . . : 00-1A-4B-E0-F0-52
  IP Address. . . . . . . . . . . . : 192.168.1.4
  DNS Servers . . . . . . . . . . . : 192.168.1.6
                                      212.xxx.xxx.18
Ethernet adapter Local Area Connection 2:
  Description . . . . . . . . . . . : HP NC1020 Gigabit Server Adapter 32 PCI
  Physical Address. . . . . . . . . : 00-18-71-4D-05-66
  IP Address. . . . . . . . . . . . : 196.xxx.xxx.74
  Subnet Mask . . . . . . . . . . . : 255.255.255.248
  Default Gateway . . . . . . . . . : 196.xxx.xxx.73
  DNS Servers . . . . . . . . . . . : 212.xxx.xxx.18
                                      212.xxx.xxx.22
  NetBIOS over Tcpip. . . . . . . . : Disabled
I am looking forward for your reply
Best regards
(in reply to elmajdal)
