Vista Firewall Cliant Problems With Outlook
All Forums >> [ISA Server 2004 Firewall] >> Firewall Client >> Vista Firewall Cliant Problems With Outlook Page: [1]
Vista Firewall Cliant Problems With Outlook - 13.Jun.2007 10:03:52 AM
comutech
Hi everyone I am in need of some help and advice hope you all can help.
Ok first off I know from reading the subject the first thing you all gong to suggest is the article on changing the isa firewall client setting for outlook from 1 to 0 (http://www.isaserver.org/articles/2004olpop3smtp.html). The thing is that this was done a long while ago in order to allow my xp client to use Microsoft Outlook.
My symptoms started when I installed vista ultimate machine onto my network, I installed the new isa firewall client and tried to access my pop and smtp to retrieve my. The error I am getting is (0x800ccc0D) cannot find  the email server  and (0x80040FC) the server name you entered cannot be found.
After monitoring the send and receive operation I got the following result, TCP 1745 unidentified and the connection closed
It is my understanding that TCP 1745 is what isa uses to facilitate communication with the isa server and firewall client note that this is only happening with vista! Also If I set the computer as a secureNAT client it work fine, so I guess the problem is the firewall client now allowing pop and smtp.
Thinking that this was a problem with my environment I tried the same situation as above at a different separate location and ran into the same problem
So guys you see my stress so can you please help me out
Thanks allot
Shannon
RE: Vista Firewall Cliant Problems With Outlook - 30.Jun.2007 9:59:40 AM
jmilito
Are you using the latest firewall client software on your vista machine... The older viersion has compatibility issues.
(in reply to comutech)
RE: Vista Firewall Cliant Problems With Outlook - 30.Jun.2007 10:04:25 AM
are the VISTA Client & ISA Server joined to the same Domain ?
RE: Vista Firewall Cliant Problems With Outlook - 1.Jul.2007 4:27:31 AM
ITEngineer
ORIGINAL: jmilito
YES
(in reply to jmilito)
RE: Vista Firewall Cliant Problems With Outlook - 1.Jul.2007 4:29:07 AM
ITEngineer
ORIGINAL: elmajdal
The Vista client is not a domain member
The ISA Server is a domain member.
i do have have problems using the Firewall Client on XP machines that are not joined to the domain .This problem only occurs with Vista .
anyone else had such issue ?
anyone using vista ?
my original problem : http://forums.isaserver.org/m_2002048077/mpage_1/key_/tm.htm#2002048158
< Message edited by ITEngineer -- 1.Jul.2007 4:32:55 AM >
(in reply to elmajdal)
