Vpn problem Small business server ISA 2004
All Forums >> [ISA Server 2004 Firewall] >> VPN >> Vpn problem Small business server ISA 2004 Page: [1]
Vpn problem Small business server ISA 2004 - 1.Mar.2005 7:10:00 PM
Dwayne75
here is my setup
Windows Small business server 2003 Isa 2004
I am trying to make a site to site PPTP VPN to a Draytek 2600g router.
I can make the connection work if the server connects to the router. But when the router tries to connect to the server I get the following error
The user dwayne connected to port VPN5-22 has been disconnected because no network protocols were successfully negotiated
[ March 01, 2005, 07:11 PM: Message edited by: Dwayne Griffiths ]
RE: Vpn problem Small business server ISA 2004 - 2.Mar.2005 1:22:00 PM
Hi Dwayne,
The ISA firewall isn't supported on SBS until the SBS team comes up with hacks for it.
(in reply to Dwayne75)
RE: Vpn problem Small business server ISA 2004 - 3.Nov.2012 10:27:48 AM
oli.hall
Soution to this problem:
In Your DrayTec router go to:
VPN and Remote Access>>LAN to LAN>>Profile Name: TCP/IP Network Settings, Remote Gateway IP.
Draytek state this should be set to 0.0.0.0 as it is configured automatically when connecting to another Draytek router.
What they forget to say is when connecting to an ISA/TMG server, you must set this manually to your Draytek router IP and not 0.0.0.0.
This solved the problem for me on a PPTP Site-to-Site VPN from a Draytek 2830n to TMG2010..
You must remember that in ISA, the name of Your VPN Network must be the same
as the username used in PPTP.
Draytek also have a username length limitation of 49 chr and password of 15 chr for Dial Out VPN. For Dial In VPN, username and password is max 11 chr. See:
http://www.draytek.com/user/SupportFAQDetail.php?ID=183
solution courtesy of Dariusz Kozicki
