WEB error
All Forums >> [ISA 2006 Publishing] >> Web Publishing >> WEB error Page: [1]
WEB error - 23.May2008 9:39:49 AM
nikit0ss
Greetings.
In our company there are published resources, they are published on external IP to addresses, the Internet of names at them is not present. The EXAMPLE: (https:/0.0.0.0./test). All works. Then ISA writes Alerts:
Description: ISA Server failed to compress the content of a response. Description: ISA Server was unable to compress a response body from 83.102.235.164 because the following error occurred: неопознанная ошибка. This error generally occurs because the available memory is insufficient for completing the compression process.
Further the Second message.
Description: The Compression Filter cannot handle a response because the memory allocated for compression is fully utilized. Description: The Compression filter cannot handle a response because the allocated memory currently used for compression reached its limit. The memory allocated for compression is specified by the following registry values under the HKLM\Software\Microsoft\RAT\Stingray\Debug\W3Filter key: COMPRESS_MEMORY_ALLOC_MBYTES (by default, 256) and COMPRESS_MEMORY_POOL_BLOCKS (by default, 200). After that the EXTERNAL PUBLISHED RESOURCES are disconnected ALL.
What to do?
P.S.  83.102.235.164 is one of our resources
RE: WEB error - 23.May2008 10:00:47 AM
IanC
One of my clients had the same problem a while back.  I was unable to get a definitive solution from Microsoft or from anyone in this community.  However, you can fix your immediate problem by disabling compression for the listener.
Here's some correspondence on the issue.
http://forums.isaserver.org/m_2002049384/mpage_1/key_compression/tm.htm#2002063151
Does anyone else have any more information regarding this one?
Ian
Ian Currie
http://www.curriecomputing.com
(in reply to nikit0ss)
